88 pickup need help!!! Struggles to start and runs like shit
Discussion in 'Engine/Drivetrain' started by Juan sifuentes, Jun 1, 2018.
Tags:
  1. Juan sifuentes
    Juan sifuentes Newbie
    I have a 1988 toyota pickup 22re efi ran like a dream till i got backed into by a semi and extremely overheated broke block and head got new head never used from lce and a good block from a shop new internals and timing kit i set timing right and does start just Struggles to start and when it does it idles at 2k and then starts surging down to 1300 and back up to 2k fresh rebuild all gaskets new all valves adjusted everything new except injectors but ran great before rebuild i bkocked off the egr the secondary air injection and heater lines really need help this is my daily driver for work
  2. Hands_On_Henry
    Hands_On_Henry Member
    Michigan
    1985 22R/4spd
    Makes me wonder if one of the Coolant Temp Sensors got fried. If you've replaced your sensors already then I would consider trying a different ECM. If the check engine light is on you could try to get a read on that for starters.
    Good Luck!
