88 pickup electrical problems..
Discussion in 'Maintenance/Repair' started by ixcocoyxi, May 3, 2007.
  1. ixcocoyxi
    ixcocoyxi Newbie
    i have an 88 toyota pickup.. my dad recently got hit on the rear (nothing major) but some problems came up..
    1) no turn signals but hazards work
    2) fuel gauge in-op
    3) 'charge' light on
    these all happened right after the hit.. i have replaced the alternator and re-charged the battery.. but the charge light is till on.. i looked for a signal/blinker fuse or relay but i was unsuccessful.. but i have found the 'fuel' relay under the hood.. would that be the cause of all 3? on the fuse cover.. theres something written on the top as so..
    ---- <- unable to read
    fuel
    heater
    all three of those is on that on relay.. and when i pulled it, it said something like 'emissions relay'.. so im kinda second-guessing myself that its not the problem..
    any insight is helpful.. thanks in advanced!!
    -coy
  2. 93Yoter
    93Yoter Addict
    Central Point, OR
    93 std. cab deluxe
    Enola should be able to tell you but I don't know when he'll be on. Your blinker fluid is probally low! Jk man I believe the turn signal fuse is in the drivers side kick panel but I don't know enoguh about the 88 just the 89-94.
  3. ixcocoyxi
    ixcocoyxi Newbie
    yeah.. i was talking to that guy on customtacos.com i believe.. and he told me that this site would be better help because from what i see, it basically deals with the older model trucks..
    and as for the fuse by the kick panel.. suprisingly.. there is no fuse for the blinker in there.. but i'll check all of them when i wake up tomorrow just to make sure..
  4. 79muttyota
    79muttyota Enthusiast
    Rome, GA
    79 sr5
    Try checking all your turn signals to see if any connecters have come loose. I know with most older cars the turn signals have to have a complete circuit to work properly. If all the wires are connected, the problem may be the blinker switch in the steering column.
  5. infotechplus
    infotechplus Newbie
    Trouble with rear lights
    In the kick panel there will be a fuse holder with lots of coloured fuses plus some relays. Your turn signals are controlled by a relay - a flasher relay. Check it for a good connection.
    Also make sure you have a good Earth as the rear lights are all on one wiring harness, including number plate lights, turn signals and stop light.
    The fuel gauge works from a two wire connector that slips onto the top of the fuel tank. It may have been dislodged or broken in the shunt.
    Hope this helps you out,
    Peter
    Sydney
    (Hilux RN85R)
  6. sudzyota
    sudzyota Newbie
    if any one has anymore info on this wiring problem my 88 toyota is having the same symptoms and i can't figure it out! any info would be appreciated.
  7. ShoNuff
    ShoNuff Toyotaholic
    seattle
    75 hilux, 80 4x4
    did the tail lights get hit?
    all blinker bulbs have to be the same to get the blinker to work.
    maybe the wire loom got pinched and is shorting under the bed?
  8. 671_22RYOTA
    671_22RYOTA Newbie
    253 Spanaway WA
    87 2wd Yota
    why are my turn signals dont work but my hazards do? I have a 1987 2wd I just got it.
    I replace the whole blinker switch on the steering wheel and checkd all the wirings and they are fine and I also check the fuses nothings blown. but im thinking its the blinker fuse I dont know can some one plz help me?
  9. randyman
    randyman Enthusiast
    georgia
    1976 hi lux 2x4
    sounds like a pinched wire on the framerail somewhere shorting things out in the rear of the truck???
