hey just wanted to show you guys some pics of my truck. i dont really have pics of how it first started but i have a few current ones. i originally had a 91 xcab hardbody lol until i swapped it for the 88. the 88 was really not in good shape. the body was all rusted out. motor needed work, clutch fork gave out so the previous owner was slamming the gears. we pulled the motor to overhaul, trans was seized and we had to crack the bell housing to remove it. changed the main and rod bearings. removed and cleaned the valves and put them on a new/used head. installed a 280 comp cam, and all the other stuff found their way on to the truck through out the years. cant remember the order. heres what i currently have: 22r MSD 6al Accel super coil Accel 8mm wires Doug Thorley headers Flowmaster 40 series (straight pipe, cat delete) 280 Comp Cam 4 inch drop front (cranked torsions) 3 inch block rear off-set weld draglites, 15x7 front 15x8 rear autogage 5" tach future mods: 32/36 weber progressive carb 5 speed celica trans posse 4.38 rear gears valve train upgrade could use some body work weld pro stars electric fan bottom end
thanks prim thanks! she is dropped. on the specs it says 4inch torsion drop but its more like 5 or so. removed bump stops. so low i cant run a valance or ill rip it off.
some clearance shots, not really on leveled floor so not as accurate. i scrap my pipe every so often running a spare, i picked up a nail on the side wall. shop said they cant jerkey it. i need a inner tube
aww that sucks.... oh well, hope you grab a new tire sometime! lol how fast do you drive to scrape the pipe or rip off the valance anyway, what you need is the 89-95 2WD valance and attach via zipties. and if it does rip off and gets flattened by your truck's tire, just hammer that bitch out. ask me how i know anyway, i'm valance-less right now too!
well for the pipe i usually scrap it on speed bumps, inclines and such. valance, i cant run one. i will chow it immediately. roads here suck. but i do want to put on a 84-88 4x4 or 4runner bumper on. the one with black ends
are u talking about the plastic ends on the bumper? i wouldnt recommend them as the break off after awhile and they dont look as good IMO..i would just paint the ends of the bumper you have to give it the black ends ur looking for...
oh, real? nevermind then. what types of valances can i run? something that doesnt hang low so i wont rip it off on the road
thanks dude, those are prime rims. i got a set of them for free had my painter paint the centers. took them off when i got my off set welds.
