87 transmission
Discussion in 'Engine/Drivetrain' started by matthew babon, Mar 10, 2025.
  1. matthew babon
    matthew babon Newbie
    thoughts on a bolt up 2wd tail section to G52 transmission in a 4wd, also an 87??
  2. sirdeuce
    sirdeuce Veteran
    '86 4Runner and '89 2WD
    4X4 and 2X4 tail shafts are different. Not sure you can make that work. The job would be more intensive than just changing the tail housing. I believe the 2WD output shaft is longer and can't just be moved to a 4WD trans.
    Try calling "Marlin Crawler" (559) 252 7295. Nobody knows Toyota transmissions better.
  3. sirdeuce
    sirdeuce Veteran
    Probably easier to just convert to a "W" series trans anyway.
  4. matthew babon
