86 22RET build
Discussion in '1984-1988 Build-Up/Project Threads' started by ranger6, Jan 11, 2011.
  1. ranger6
    ranger6 Member
    Marysville, Wa
    86 22RTE
    I found this to replace my 78 that was totalled out. 80K, and $2500. I have a stroker cam and some Mustang rims that will be first on the list to install, if it ever warms up here.
  2. oahu grown
    oahu grown Toyotaholic
    Hawaii
    92 Extra Cab
    Nice platform you got there. Looks like all original paint and original interior. Nice score.
  3. tyme_fo_play
    tyme_fo_play Addict
    94 BLOCK HAWAII
    MY PRIDE MY JOY MY TOY!
    wanna sell your rims after you put on your mustangs? nice truck btw!
  4. rink45
    rink45 Enthusiast
    vancouver, wa
    78 shortbed
    very nice find!
  5. drama808
    drama808 Member
    North Dakota
    84 xtra cab, 75 Long Bed, 09 Ruckus
    Yeah, great buy man. That thing looks pretty minty.
  6. garagedoorman
    garagedoorman Addict
    north georgia
    Ranger, I'm exited to see you get another truck.And a turbo, ataboy! A quick note, look into using the cam on that engine before swapping. I could be wrong, but I believe a turbo cam is different from a N/A cam. The lift is different. Call LCE Tech support and ask . They will give you an educated response about usage. Never the less great score:bowdown::waytogo:
  7. ranger6
    ranger6 Member
    Marysville, Wa
    86 22RTE
    Cam
    I talked with engnbldr and he informed me it should work just fine. I will however contact LC and ask them as well.
  8. DionTDE
    DionTDE Addict
    Preston, ID
    93 single cab 2wd
    That is awesome! I wish i could find a 22RET. I would like a manual transmission, the automatics just do not drive right when they are turbocharged.
  9. CurtisZ
    CurtisZ Addict
    Lake Stevens, WA
    1978 Pickup Longbed
    Sweet find!
  10. ranger6
    ranger6 Member
    Marysville, Wa
    86 22RTE
    New turbo
    Just installed a new Honeywell ATS200-82 running BP2197 oil and a new Honeywell pneumatic valve with 4" SS down pipe.
    Just kidding. You think these Toyotas are confusing.
  11. ranger6
    ranger6 Member
    Marysville, Wa
    86 22RTE
    Belltech drop spindles
    I installed the drop spindles this morning. There's some things that need to be addressed when performing this operation. I will add photos later. with the standard 14" SR5 turbo rims, the dust cover for the brakes needs to be trimmed at the front. When installing the new spindles you don't use the Knuckle arm. So, the two bolts that go through the dust cover are not used as well. The new Belltech spindles have threaded holes that you must fill with new fasteners. Also, both wheels toe out and need to be realigned. Just some thoughts on this type of swap.
  12. Malessohomegrown
    Malessohomegrown Toyotaholic
    Malesso,Guam
    Nice
    Wow truck in nice and clean. Would be great if it was a standard to see what that turbo could do.
  13. Dgerfan55
    Dgerfan55 Grand Toyotaholic
    lake elsinore CA
    94 pickup
    Nice and good tips man. Now on with the pics
  14. ranger6
    ranger6 Member
    Marysville, Wa
    86 22RTE
    Lowering
    This with 2" drop spindles and 1" blocks in the back. The 2" blocks made the rearend rub around tight corners.
  15. B.Y.E.
    B.Y.E. Toyotaholic
    "671" Houston, Texas
    1982 2wd Hilux
    Looks good bro!
    Try a lower profile tire or just sell me them wheels if they keep rubbing! :evil:
  16. jctoy29
    jctoy29 Addict
    surprise,az
    Truck looks like its in good shape, but you can't tell that it s been lowered. But it's a nice ride.
  17. ToxicToyz
    ToxicToyz Addict
    HI
    88 longbed
    The leaf spring bushings might be worn out if the back rubs in corners . Or could be the tires too big
  18. ranger6
    ranger6 Member
    Marysville, Wa
    86 22RTE
    New stuff
    Mustang rims, a 2 1/2" cat free exhaust and a gauge cluster.
  19. tyme_fo_play
    tyme_fo_play Addict
    94 BLOCK HAWAII
    What you gonna do with the turbo rims?
  20. ranger6
    ranger6 Member
    Marysville, Wa
    86 22RTE
    They're in perfect condition less the center caps are missing a little paint, I'll sell them.
