82 toyota celica supra AFM
Discussion in 'Parts and Accessories' started by SD YOTA, Mar 29, 2014.
  1. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    got this AFM here from a running car that was being parted out. this is the AFM to be used for the big bore intake mod. hard to come by these days unless you wanna pay out the nose for a new or reman'd one. letting this go for $100 shipped in the U.S. located in San Diego.
    comparison next to the stock 22RE one...
  2. silverblazer50
    silverblazer50 Enthusiast
    Thomasville GA
    1994 reg cab
    So I would take the guts out of mine and out in this?
  3. SD YOTA
    no... you plug this one into where your stock one goes. nothing is used from your stock afm. you will likely need to use a larger intake coupler since the opening is larger on the supra afm. you then open the top cover and adjust the afm to suit your motors needs.
    this video explains how to adjust it...
    https://www.youtube.com/watch?v=AydgSxSKzD4
  4. tacobo670
    tacobo670 Addict
    Las Vegas
    94 Base
    i thought the only ones that are plug n play are the 22250-43110? -for the 22re
    pls correct me if im wrong.
  5. SD YOTA
    someone posted this info on yotatech wich is what ive been going off of. not sure as far as the numbers being correct. thought so too till i checked this link. this afm did come off an 82 celica supra tho.
    proper vafm swap for the 3vze - YotaTech Forums
  6. SD YOTA
