8 inch rear axle swap to 84
Discussion in 'Suspension/Chassis' started by Shoosty, Mar 5, 2021.
  1. Shoosty
    Shoosty Newbie
    Would a toyota (code g i think its called), 8 inch rear axle fit on an 84 pickup? are the 8 inches all the same from the 80s and 90s?
  2. Justin Danger
    Justin Danger Toyotaholic
    Bay Area Peninsula
    My turbo came with a g code 8 inch rear, and it is an 86'. I don't know about cross generational compatibility.
  3. jetas
    84-88 trucks had 8" diffs available
  4. fred heath
    fred heath Addict
    Raleigh, NC
    GO82 is the part number for Toyota’s 8” (3/4 ton) axle. Standard axle has a 7.5” R&P and unequal axle shafts. 8” axle shafts are interchangeable left to right.
    Everything thing should swap equal. May need different fabric hose setup for brakes. Keep in mind replacement axle shafts for the 8” are no longer available, either factory or aftermarket. Toyota used these axles on early motorhomes. Do not buy a motorhome 8” axle. It will probably be weak and prone to breaking.
  5. Shoosty
    Shoosty Newbie
    BOYS IMA BUY ANOTHER YOTA PICKUP!!!
    Erwin Merida likes this.
  6. sirdeuce
    sirdeuce Veteran
    '86 4Runner and '89 2WD
    Axle housimg swaps would be limited by the spring perches, unless you want to cut and weld. Other considerations would be the length. An '86 4X4 is wider than an '84 and a good swap for an '84 4X4.
