76-83 Vent Window Rubber on a 71' Hilux?
Discussion in 'Exterior/Body' started by Panzer, Jun 27, 2012.
  1. Panzer
    Panzer Newbie
    Still looking for restoration options on a 1971 Hilux front vent window (wing window) rubber. Does anyone know if the rubber from a 76-83 will fit, even with some minor trimming?
    As a side note I am also looking at Land Cruiser FJ 55 rubber but its probably no dice... If the 76-83 fits, I'll do a build up thread of the restoration and what parts can be substituted.
    Geeze! Parts are hard to find on this thing! :brickknock:
  2. 1982rn34
    1982rn34 Addict
    Bay Area 408
    1982 SR5 RN34
    First of all, the vent window weatherstrip for the '79-'83 trucks are still available through Toyota.
    (LH: 68182-89104 / RH: 68181-89104). I imagine that the door didn't change drastically, so you will need to modify them to fit. If it were me, I'd give it a try.
    Let us know what you decide!
    Rick
  3. not forgotten
    not forgotten Addict
    Washington
    82 SR5 L/B
    http://www.toyotaminis.com/forum/pa...utside-wing-style-window-weather-strip-11101/
    This offer still stands, I have no use for them anymore and would like to see someone use them instead of just sitting in the garage collecting dust.
    I just called our local dealer parts dept and he said they sell for $22.72 each, so you'll save a few bucks anyway for the same product, these were on the truck but it never left the garage, did my one piece window swap a few weeks later.
    Send me a PM if interested, I have sold a few things here before you can make a post and check me out, I am sure you'll get positive answers back, always went really smooth
    Pete
  4. not forgotten
    Washington
    82 SR5 L/B
    My mistake, I did drive the truck with them on as stated, about 15 miles, dry conditions.
  5. 1982rn34
    1982rn34 Addict
    Bay Area 408
    1982 SR5 RN34
    Hey Pete,
    Your link that you posted advertises the side window weatherstrips (aka door belts). He's looking for the weatherstrips for the vent windows.:)
    Rick
  6. not forgotten
    Washington
    82 SR5 L/B
    I see now what you mean, I don't know why I thought it was the side door belts. Thanks Rick.
    Ignore my offer, I don't have those. I had stock side and wing windows and the rubber was part of the wing window, but those are long gone.
    I would call your local dealer/parts dept and use the part # Rick posted and even ask them if the computerized pic on their screen looks like the same part and would it fit. I would'nt think it would be that much $ and you would have 2 brand new pieces.
    Good luck with this
  7. Panzer
    Panzer Newbie
    I tried it... The 76-83 vent window rubber will not/not fit on a 68-71 Hilux. It misses the top section (apex) of the triangle by about 1/8 of an inch e.g. the 76-83 has a shorter (vertical length) wing window. Sorry for the trigonometry references... After studying (pun intended) it for a while, a small portion of the old gasket could be cut out to lengthen the left and right legs as well as the hypotenuses and sealed with black silicone.
    The problem is the gaskets on the truck are too dry and you have to be very precise with the cuts so as to not destroy a $40 set of gaskets. All I need is a not so dry set of donor gaskets to make it work. The saga continues...
