5spd swap
Discussion in 'Engine/Drivetrain' started by David Velez, Jun 13, 2021.
  1. David Velez
    David Velez Newbie
    Good day everyone ,,, anybody know what 5spd will fit the 8r engine. This 4spd just not my liking. Lol. Any body swap one before
  2. sirdeuce
    sirdeuce Veteran
    '86 4Runner and '89 2WD
    I believe the R family engines have the same bolt pattern for the bell housing. Issue may be the rear mount.
  3. David Velez
    David Velez Newbie
    Was wondering if the t50 would work ?
  4. sirdeuce
    sirdeuce Veteran
    Might work with an adapter plate, but I woulldn't recommend it. T50 has great ratios, but it's a bit on the weak side. Best bet is a W5X. Celica, Supra, Cressida, Corona, Pickup. Plenty out there.
    Sounds like a trip to the local Pick Your Part is in order. Great place to do research. Take a tape measure. Measure your trans from face of bell housing to rear mount and shifter base and crawl under a few cars and trucks to make comparisons.
  5. David Velez
    David Velez Newbie
    Thanks for the reply also hearing a 22r 5spd will bolt right . Not sure how true that is either . W58 etc are super rare here in Florida. And if found people want a arm leg etc.
  6. sirdeuce
    sirdeuce Veteran
    Have to ask, What trans are you starting with? 4 speed is a bit vague.
  7. sirdeuce
    sirdeuce Veteran
    is your trans cast iron, G series, or aluminum, W series?
  8. David Velez
    David Velez Newbie
    All I know cause I just bought it. Still doing homework on it. That it's a 8r 4spd
  9. sirdeuce
    sirdeuce Veteran
    If the case is aluminum it is likely a W40 or W42. In which case the most you might have to do is redrill the rear mount holes in the crossmember and/or make a plate that bolts to the trans mount and frame. Not sure about a G trans though, prbably the same.
  10. Henry
    Henry Enthusiast
    Washington State
    I did the W50 swap on my 20R and all I had to do was modify the transmission mount. I went a little overboard but you could easily modify it to accept the 5 spd. I had the L42?W42? Whatever 4 spd was found in the 77 pickup.
