5 Lug Convert to 4 lug??
Discussion in 'Wheels/Tires' started by randomxzero, Aug 23, 2008.
  1. randomxzero
    randomxzero Member
    has anyone done it on these trucks??
    i want to do it...
    but i havent found any info on that..
    all the wheels with sick negative offset are old school 4.114.3 wheels and i want to convert my 5 lug to that.
    but i need some info on it plz :D
    some wheels like these<br>
    <img src="http://www.ratdat.com/images/wheels/enkei_ap_racing.jpg"/>
    <br>
    <img src="http://www.ratdat.com/images/wheels/hoshino_impulG5.jpg"/>
    something with some real negative offset and a deep lip :D
  2. randomxzero
    randomxzero Member
    bumpitty bump
  3. burnzya
    burnzya Grand Toyotaholic
    arizona city, arizona
    bodied 73 hilux
    i think your the first person to ever want to go backwards to 4 lug. have you looked into any wheels that you can get a custom offset?
  4. grounds671
    grounds671 Veteran
    tampa
    1995 pickup std
    if i was you id go buy and adapter first and go from there. 5 to 4 lug it sells on ebay.
  5. randomxzero
    randomxzero Member
    ya ya i know they sell the adapters but im not familiar with the whole conversion. Ya i have checked out tons off wheels that were 5 lug but none have that offset that i want
    And the Wheels that have the offset a lot of people are rockin em
    I was going to go with 5 lug centerline but a lot trucks here in so cal have em.
    :/ so i want to go with old school
  6. ShoNuff
    ShoNuff Toyotaholic
    seattle
    75 hilux, 80 4x4
    try looking at 70's ford rims for a deep lip.
    and pre78 corona's have 4 lug and a A arm setup, you could prolly make the rotors/hubs work, and i know there were more then a few 4-lug leaf sprung axl's (vans,corona's, old rolla's).
    these are a ford pattern
    and there is a TON more rim options with a 5 lug then a 4lug.
  7. randomxzero
    randomxzero Member
    ya bu not for the style of wheel im looking for..
    but maybe if you can give me a website i wont do the conversion:D
    save myself some time :D.
    ya i know the 81 rolla wagon has the leaf spring setup in the leaf spring setup in the back.
  8. cEElint
    cEElint Enthusiast
    Bakerstink, CA
    '91 Yota STD
    what kinda offset you lookin for?
    Sportmax's have a decent offset w/ nice size lips.. and kinda old skool looking
  9. randomxzero
    randomxzero Member
    ha
    sportmaxx's are okay but go to honda and the 4 lug forums a bunch of people are rockin em.
    im looking for pretty sick offset something with a nice 4"-5" lip :D maybe 3" ill go but also has to have offset where the lugs go because i really dont want the volk looking rims
  10. grounds671
    grounds671 Veteran
    tampa
    1995 pickup std
    dam your picky:D
  11. randomxzero
    randomxzero Member
    haha
    ya its the whole look im going for..
    it's really different and not seen often so i want to make sure.. i drop jaws when i post up pics of my finished project :D
  12. Monzter Kuztomz
    Monzter Kuztomz Newbie
    Pittsburg, CA
    Pull off your front rotors ( or buy new ones ), rear drums ( or buy new ones ) & axle shafts ( cut the bearings off & remove the backing plates ). Them send your rotors, drums & axles to Dutchman Motorsports http://www.dutchmanms.com/pricesheet.html#Anchor-65143
    It's not gonna be cheep, but they'll get it done.
  13. randomxzero
    randomxzero Member
    thanks man! :thumbsup:
  14. blazinrola80
    blazinrola80 Member
    try swaping axles with a toyota van 86 era.. with the pointy front end they are 4 lug.. as for the ft machine your ft hubs to 4x114.4
    could also do 4x100 and do the work wheels with the 5.5 inch lip.. 4 spoke ones..
  15. rwmagee90
    rwmagee90 Enthusiast
    Rock Hill,SC
    1989 STD. Cab (base)
  16. patriotpop
    patriotpop Addict
    Baltimore, MD
    94 2wd
    Man those are 2" thick, your going to need one hell of an offset!!
  17. rwmagee90
    Rock Hill,SC
    i figured the would be ok with some 15x7 or 16x7 around a +40 offset with 4wd fenders not too sure though i was going to check with a wheel shop to see if they had any recommendations. when in doubt ask a pro, right?
  18. Yodaforce
    Yodaforce Member
    This is almost rediculous. I understand you want a wheel that is different, but trust me, EVERY WHEEL YOU COULD IMAGINE is being run by someone else, somewhere. Different is a hard game to play. If you can think it, someone else has allready thought it! In a quest to be completely different, many car builders have built some extraordinary machines, but they teeter on the line of gawdy. What you need to do is consider what you like (as far as wheels), and start contacting every company out there to find it in a 5-lug. As far as a 3-5 inch lip, I would think that by the time it's all said and done, you would need to flare your fenders out atleast 4inches to get that kind of look. Otherwise you would have to get a wheel about 4-5 inches wide so the extreme offset you desire doesn't put the tire into the frame, or control arms.
  19. randomxzero
    randomxzero Member
    ^^ ya yoda but the thing is no one is rockin the wheels i want on the toyo pickups..
    no one is rockin the style i want on these pickups..
    i have only seen a couple of trucks that are near the style i want!!
    but they are old school datsuns..
    wait and see when my project is done..
    you will see what style i went for
  20. cEElint
    cEElint Enthusiast
    Bakerstink, CA
    '91 Yota STD
    Tryin to go VIP style or something?
