4x4 to 2wd Front Suspension
Discussion in 'Suspension/Chassis' started by smartmonkey, Mar 8, 2013.
  1. smartmonkey
    smartmonkey Veteran
    Australia
    v320, 620, 720KC, RN46, LN46, YN65 & B2200
    I have exteneded the rear my 83 Crew cab and want to run a 90s 2wd front suspension on the front. I am going to Z the front 1.5 inches at the same time... Can I just use the front clip of the 90s chassis? or will I do I have to run with the 83 frame?
  2. riceratyota
    riceratyota Veteran
    backwoods oklahoma
    which one 77/78/79/81[r.i.p]82 sbrc driftbox, and a CeliLux/current daily= 79 sbrc [lil' blue]
    just use 90's stuff under 83 since i assume your slamming it the 4x4 frame is useless to you just cut and stretch the 90 frame and adapt mounts to the 83 body points
  3. riceratyota
    riceratyota Veteran
    backwoods oklahoma
    plus lots available for newer 2wd front ends
  4. smartmonkey
    smartmonkey Veteran
    Australia
    Phew :bowdown: lucky I didnt cut the front just yet. Thanks man! I have a spare 82 Crew cab so I'll just lift one and bag the other on a 90s frame. Thanks again. :waytogo:
  5. riceratyota
    riceratyota Veteran
    backwoods oklahoma
    post pics as you go we will be watching:cool:
