4x4 fenders
Discussion in 'Exterior/Body' started by SamuelsToy, Oct 17, 2010.
  1. SamuelsToy
    SamuelsToy Member
    Grifton, NC
    1994 xcab pickup
    Ok i found some 4x4 fenders on craigslist for free the other day, i picked them up and put them on my truck, they bolted up fine, but there is gaps in between the hood and the fender, the fender sticks out a little further than the door, and the top part by the windshield has a slight gap as well, is this normal, or is it because i didnt line it up or whatever before i bolted it up?
  2. Dgerfan55
    Dgerfan55 Grand Toyotaholic
    lake elsinore CA
    94 pickup
    I have the same problem. i was wondering the same thing
  3. IronNam
    are they OEM?
  4. SamuelsToy
    SamuelsToy Member
    Grifton, NC
    1994 xcab pickup
    as far as i know they are, but like i said i got them from someone for free so i aint complainin, just tryin to see if its supposed to have the gaps or not, i hope not but oh well
  5. V8_TITAN
    V8_TITAN Toyotaholic
    Tampa Fl
    89 std cab
    you need to loosen all the bolts, figure out if you need shims or if you can just move it around.. mine are aftermarket and they fit fine ! they just dent super easy !
  6. SamuelsToy
    SamuelsToy Member
    Grifton, NC
    1994 xcab pickup
    yea when i got them the bolt hole that goes on the inside of the door was bent on the passenger fender, so i pulled it out, maybe i should recheck it to see if i pulled it out all the way, i dunno, gonna unbolt it tomorow if the wife dont have the baby, and see if i cant maneuver it around or if i have to shim it. hope it just needs to be moved around a bit
  7. V8_TITAN
    Tampa Fl
    89 std cab
    most likely what it is... oh and the gap by the windshield is normal... like 1/4 inch...
  8. SamuelsToy
    SamuelsToy Member
    Grifton, NC
    1994 xcab pickup
    yea i believe its a 1/4 inch or so, real small but i notice it so it kinda ticks me off, and the only other bad part is im gonna have to run without corner lights, but i plan on shaving those as soon as i get a phantom grille
