4runner back window project.
Discussion in 'Exterior/Body' started by MTB68TOY, Jul 28, 2010.
  1. MTB68TOY
    MTB68TOY Addict
    Jackson NJ
    I am sure that im crazy for doing this but here it is...
    I am going to cut it a bit smaller before attaching but you get the idea, I am planning to line up the stock body mount left on the 4runner cut with the front bed mounts. I am going to cut the mounts off the runners frame and weld them to the front bed mounts.
    Any suggestions for a good sheet metal welder? I am planning on buying a new one.
    anyway here are the pics...
    lets here some opinions!!!
  2. dillinja666
    dillinja666 Toyotaholic
    I gots no truck, for now
    i r confused...are you trying to graft the back window of the 4 runner into the truck and make an extended cag thing or the whole back of the 4 runner into the back of the truck...cause the way it looks right now, it looks like you are either going to have tail lights in front of the bed, or a really short truck you put wheels under the 4 runner part...
  3. TheLoLux
    TheLoLux Toyotaholic
    Simi Valley, CA
    you start doing all that welding on the cab. you should think a bout use a tig welder
  4. Dcups
    Dcups Addict
    Seattle
    93 Std Cab chassis/4Runner 2door body
    Cool project!! I get what your trying to do...
    but you need to Por-15 that frame while you have the body off of it.
    are you going to weld the bed to the cab?
  5. yota4life
    yota4life Grand Toyotaholic
    lodi ca
    1991 xcab 2wd 4cyl
    Huh definitely different I like it
  6. WDE_BDY
    WDE_BDY Member
    New Zealand
    1981 Toyota Corolla minitruck
    You going to retain the opening tailgate or are you just after the electric rear window? I know there is a later model Surf/4 Runner with one peice tailgate that could be worth a look.
    Callum
  7. MTB68TOY
    MTB68TOY Addict
    Jackson NJ
    Actually considered the 96-99? one piece gate but figured this would line up better and I want to keep the gate functional. plus those gates are way expensive, bought my whole parts runner for less than just that gate would cost...
    thanks!
    The frame is going to get sandblasted after I finish mocking up my motor mounts, since I finally got the bed off today (those front two bed bolts were a biatch)
    I wanted to see how the runner cut lined up.
    The frame will get a coat of silver bullet (por-15 is uv sensitive and needs to be thinned to spray, bullet is not uv sensitive and ready to spray)
    As for the bed: three choices 1. double bob the existing bed to fit 2. get a full glass bed made from toyotafiberglass.com or 3. just get bed sides made and hang them with an open frame pre-runner style
    I'm leaning towards option 3 at this point and no I won't be welding the bed to the cab
    thinking about a mig with an argon shield, also just thinking of hiring a "metal banger" as our friends from OZ say (right Callum! love your truck by the way partly my inspiration to go for it)
    I think I "R" confused now too.... (8
    maybe if I attach the rear directly to the trans... dunno but the short 4runner is an interesting idea.....
    nahhhh think I'll just weld up the tail-lights and put a short bed on it!
  8. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    I'd probably try the double bob first. An if you don't like it then get one made.
  9. MTB68TOY
    MTB68TOY Addict
    Jackson NJ
    Have had that thought myself... But, if I don't like it I killed a decent bed and then I have less fuel cell options
    The fiberglass bedsides only with an open frame leaves me any option I want for a fuel cell
    I am considering a long flat marine tank
    50-60 gallons laying on top of the frame
    Whatever I do I want the gas filler neck right in the middle of the back so I can get gas from either side...! (8
  10. burnzya
    burnzya Grand Toyotaholic
    arizona city, arizona
    bodied 73 hilux
    pretty neat idea!
    i think once it's done it well resemble the roof line of the new extended cab tundra's!! :D
    what's the plan for the roof? maybe section the body above the bodyline to bring the roof down a bit?
  11. Dcups
    Dcups Addict
    Seattle
    I think it would be cool too if he could still use the tailgate and open it but that means the floor of the bed would need to be lowered to accommodate for the tailgate opening
  12. WDE_BDY
    WDE_BDY Member
    New Zealand
    Yeah they swing down quite a bit, could set it to drop only so far down and have the tray floor drop at the same time. If its bagged though you are going to run into clearance issues with the bridge and driveshaft.
    Callum
  13. IronNam
    i say weld from the inside (if anyone said that already, whoops lol)
  14. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    Cool project. Going to retain part of the window opening or just have a huge fatty pillar there? I like the concept. I would just shorten the stock bed up front to match up to the cab. Yeah it might risk a good bed, but spending money for the same thing you could build from a stock one seems silly. As for the roof, my vote goes to a large ragtop. Less sheetmetal to have to weld. :D
  15. MTB68TOY
    MTB68TOY Addict
    Jackson NJ
    the runner is actually about an inch wider here and another taller...
    It will come down a bit more but I am mostly planning to line up the pillar area best I can and leave the roof a little bumped up there.
    No matter how far I can drop the gate it is not getting welded shut!
    No bags! maybe coilovers someday but no bags just a 2/3 static drop
    thinking no bed floor... just open like a desert truck
    please any sugestions on building this I appreciate... not sure if I can get to too many inside areas actually, the inner body blocks access
    ragtop is an idea...
    I am actually going to cut the runner part smaller. I only want to add about 10 inches max, it's closer to 12+ right now.
    the final cut should be right about where the back upper corner of the runner side window is... this adds about 6 inches to the roof line and with the angle of the back window about 8-10 to the lower body
    I will fill in whatever window area is left, so yes a thick pillar, I drive an FJ Cruiser so I am used to thick pillar blind spots! LOL
    as for the bed between the gate opening and my plan for a large fuel cell... I think and open floor setup with just bedsides hanging would work best, like the desert race trucks...
    I am thinking I can pop off the bedsides whenever I want and slap some huge slicks on it and take it to the track! (8
    plus no wheel wells will offer me plenty of rear tire options, I am thinking maybe even flared a bit to cover 10.5" wide rims...
  16. WDE_BDY
    WDE_BDY Member
    New Zealand
    If you want I can grab some measurements from my Corolla (running Surf/4 Runner tailgate) to let you know the clearance you need for the tailgate.
    Callum
  17. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    For the bed floor I'd try a nice wood one just a thought
  18. MTB68TOY
    MTB68TOY Addict
    Jackson NJ
    Thanks Mate! I'll let you know if I need any, I do have a gate so I think I'm good for now.
    I just wish I could borrow your metal banger!
    I have been thinking the same thing! Oak or Cedar with a polished stainless steel end strip.
    I am thinking only as wide as the frame and then short up front to clear the gate, at the back right in the middle an aluminum gas fill neck sticking up through.
  19. IronNam
    Do the removable bedside thing. 10.5" Wide wheels are legit.
    Gawd I want wide wide wide wide wide wheels.
    Good luck with the project fellow friend, You make good progress.
  20. JamesD
    JamesD Veteran
    NY
    93 Reg cab
