3vze help
Discussion in 'Engine/Drivetrain' started by LOW-YOTA, Apr 26, 2010.
  1. LOW-YOTA
    LOW-YOTA Newbie
    MANDEVILLE LA.
    1992 TOYOTA P-UP
    the other day i was driving my truck and stoped to get a drink. i restarted it and it just died. i made it back home and have tried everything to fix it. the truck will not idel good and when i give it gas it just stalls out. i have changed the gas. new fuel filter. and cleaned the plugs. and does any one know how to check for codes without a scanner
  2. jetas
    I forgot what pin-out it is but u have to run a wire from 1 to another, then turn the key and count the flashies of the CEL.
    Go to ur fusebox under the hood and there should be a connector on the box. the 2 pinouts are on that connector.
    Did any of this make sense?
  3. planemos
    planemos Toyotaholic
    British Columbia
    Make sure your fuel pump is working. My 3VZ truck like yours just died and it turned out I needed a new pump. Since you changed the filter you may be on the right track there.
  4. jetas
    i think all the 3.0s are takin dumps. I just replaced the gaskets on mine and it just wont start/stay on/ or idle
