2wd Toyota pick up 3rz swap
Discussion in 'Introduce Yourself' started by SprinlkerFitter 709, Jul 14, 2017.
  1. SprinlkerFitter 709
    SprinlkerFitter 709 Newbie
    Puyallup, Wa
    92 Toyota pick up
    Hello, I've got a 1992 Toyota pick up 2wd 5-speed. I've installed a '01-'04 jdm 3rz but now I'm having some clearance issues with the oil pan hitting the steering drag link, sway bar, and cross member. Even dough I have the short oil pan. I think I'm going to fabricate my own cross member but I still need to figure out the rest. I can't seem to find any 3rz swaps for 2wd pick ups, so any info is much appreciated. Thanks
    TACO626 likes this.
  2. jetas
    Post pictures and we can all give you some input
  3. SprinlkerFitter 709
    Puyallup, Wa
    92 Toyota pick up
  4. SprinlkerFitter 709
    Puyallup, Wa
    92 Toyota pick up
  5. SprinlkerFitter 709
    Puyallup, Wa
    92 Toyota pick up
    As you can see, it's not by much but still a big problem for me. I plan to drop it with Bell tech spindles and I'm not sure if that's going to maybe worsen the problem.
  6. Tuhd The Troll
    Tuhd The Troll Veteran
    Houston, TX
    1982 SR5
    Is there enough space inside the pan to hammer the clearance into it?
  7. YOguyDA
    YOguyDA Addict
    Sacramento, CA
    1986 Regular Cab
    It may look different in person, but it looks like u have a little room to spare above the intake manifold?
    Can u shim the engine up a bit?
  8. TACO626
    TACO626 Newbie
    Montclair, CA
    87 pickup 2wd
  9. SprinlkerFitter 709
    Puyallup, Wa
    92 Toyota pick up
    Hello everyone, I haven't had time to work on my truck, but yeah I will try shiming it up this weekend.
    I'm not sure about banging in the oil pan.
  10. SprinlkerFitter 709
    Puyallup, Wa
    92 Toyota pick up
    As for the mounts, I already have these installed in my truck. I bought from chilkat. Perfect fit.
  11. YOguyDA
    YOguyDA Addict
    Sacramento, CA
    1986 Regular Cab
    If you have the room @ the firewall/trans tunnel, I'd rather deal with modifying the hood than losing my sway bar and dealing with all of your clearance issues, lol.
  12. YOguyDA
    YOguyDA Addict
    Sacramento, CA
    1986 Regular Cab
    I'm super curious how this turns out btw, lol.
    I've been dreaming about a 1uz, but CA smog has me leaning this direction.
  13. Ryno5150
    Ryno5150 Member
    Suwanee, GA
    89 2WD reg cab, 85 4Runner
    Any updates on this? I'm thinking about doing this to my 91. I have pretty much every part needed because I was gonna 3RZ swap my 85 4Runner. Now I'm thinking I want to do it to my 2WD 1st.
  14. 2rz_noshit
    2rz_noshit Newbie
    I have the same issue, for the cross bar I just cut and welded a plate lower, now I am going to tackle the sway bar and center bar link.
    Erwin Merida likes this.
  15. pingpongstar
    pingpongstar Newbie
    Colorado
    1994 single cab
    On my swap I just raised the engine about 3/4" and hammered the back of the oil pan in a little. Been daily driving it for almost a year with no issues.
