22re timing help
Discussion in 'Maintenance/Repair' started by alva91, May 19, 2018.
  1. alva91
    alva91 Newbie
    shafter,ca
    1994 Toyota pickup 2wd
    So I replaced my head gasket on my 22re and now it does want to start just cranks. Need help, is my timing right. Do I install the distributor at tdc or 5 btdc. 20180519_164254.jpg 20180519_164310.jpg 20180519_164348.jpg 20180519_164310.jpg
  2. Hands_On_Henry
    Hands_On_Henry Member
    Michigan
    1985 22R/4spd
    Install the dizzy while the engine is at TDC.
    The rotor does need to end up pointing directly at the #1 after it rotates a little on it's way in.
    Hard to tell but it kind of looks like the rotor needs to be turned a little further clockwise, there's a chance that you are a tooth or two off with the dizzy drive gear.
  3. alva91
    alva91 Newbie
    shafter,ca
    OK thanks, I'm going to install it at tdc and see what happens.
  4. jetas
    The dowel pin on the cam is supposed to be a little to the passenger side, not straight up
  5. fred heath
    fred heath Addict
    Raleigh, NC
    Be sure you’re at TDC on the compression stroke.
    Hands_On_Henry and jetas like this.
