22re emission removal write-up
Discussion in 'Engine/Drivetrain' started by Xs5875, Dec 29, 2013.
  1. Xs5875
    Xs5875 Addict
    Greenville, Ga
    1994 Standard cab 22re 5 spd
    Ok, this is another topic that gets beat to death. Alot depends on how you use your trucK, where you live and the local emissions requirements.
    My truck? Just for fun/shows. I also do not live in a county where emissions are required.
    I am aware of the massive debate on how removing the EGR can cause pinging and what not. Theres just as many that say it doesn't that say it does. I have not experienced this phenomenon, and I run 87 octane.
    That being said, here goes.
    Common question #1.."What vacuum lines can I eliminate?"
    Answer...Depends. If you want a bare bones engine(like mine) You can eliminate every single one of them but 1. I have 1 vacuum line on my engine..its for the Fuel Pressure Regulator.
    Question #2...whats that round thing by the intake that attaches to the intake?
    Andwer.... The ugly thing under the intake is the AS. Or "air suction". It works in conjunction with a vacuum line, the air filter box and the exhaust manifold to basically inject fresh air into the exhaust at certain throttle plate opening angles(exposing one of the vacuum ports on the throttle body to vacuum) to promote the further burning of residual combustible material in the exhaust...(clean emissions, see the trend?) Delete it. Take it off and trash it if you want to, even the stupid tube that goes around behind the head and is a pain in the ass when you remove the exhaust manifold. Take the plates its welded to and cut them off the tube and weld the holes closed. Or buy the LCE block off plates...your money, your call. If this is all you wanna delete, trace and cap the appropriate vacuum ports and your done, if not...keep reading.
    Question #3.."Can I remove the EGR?"
    Answer...Yes. I have already briefed you on the debate..pinging, performance, and mpg..whatever. I dont notice a single difference. I do know that my intake stays clean now. Take it off, and scrap it. Take the plastic hockey puck(modulator) its attached to via vacuum lines and throw it at a stray cat.
    It works on the same principle as the AS as far as how its actuated. The 4 ports on the Throttle body dont see vacuum all the time, only at certain throttle plate angles..dont believe me take your intake pipe off look in there at the top and work your butterfly with your hand.
    You can take the EGR and trace an outline on some 3/16" plate and make some blockoffs for where it attached to the head and the intake, or you can buy some from LCE...your money, your call. If thats all you want to eliminate, cap off the appropriate vacuum ports, and your done..if not, keep reading.
    Question #4....Whats left?
    Answer...Well, your stuck now with the FPR (fuel pressure regulator) and the AC idle up vacuum lines..which both attach to VSVs, or vacuum switching valves,(those electric things on top of your valve cover) more on those in a minute.
    First, the FPR vacuum line. Follow along with me....as you get harder in the gas pedal, the more fuel pressure needed, right? So thats where the FPR comes in, from the factory its on a VSV. Basically at a certain throttle blade opening, maybe under hard acceleration,(high manifold vacuum) the FPR VSV is actuated, which lets vacuum hit the FPR and then the fuel rail pressure is elevated...I bypassed all that BS and put the vacuum line straight from the FPR to the triple vacuum adapter at the back of the upper intake. Read more on this on other forums, its where I got the idea, I have suffered no ill effects from this.
    Second, the AC idle up vacuum. This is easy. I dont have AC. So I removed it, but if you are like me, you learn better knowing how the system works before you go willy nilly cutting stuff. All cars while idling at a stop with the AC on, you notice the idle go up and down as the AC compressor kicks on and off right? This is what the AC VSV does. It lets air get past the throttle plate when the AC compressor comes on so it doesnt bog your engine down. You have to live with this if you want AC...me? Im bodied and dont have AC...so I removed it, all of it.
    This leaves you with the one vacuum line, from the FPR to the triple vacuum adapter. The picture Im gonna post in a minute is my engine, with all the ports capped. I have since removed the ports and welded the holes up on the throttle body for the ultimate smooth look.
    Now what about the VSVs? The electric solenoids under there. Sell em on ebay. Throw them at the neighbors dog. Dont need em. Now you have harness pigtails...cut em..keep em though, you never know who may need it (KERTWOOD?) LOL. This show season I just had the wires cut and taped and hidden. I have since pulled the entire harness and removed the conduit and tape and taken the whole wire out and depinned it from the connectors...makes the harness a smaller diameter and you can clean your engine bay up nicely. While you have the harness out, pull a schematic and using a multimeter set to continuity, just check each wire on your harness connectors, they call this "pinning out" and you can make sure none of the existing wires have any breaks or anything. My multimeter has an audible setting, where when it detects continuity it sounds like a cricket stuck on chirp..all mine checked out nicely. Now when I put the engine back in I wont be freaked out about "did I remove the right wire?
    Plus youll learn more about your engine. This is really easy..you can go even further too...I removed my cold start injector and cut the boss off the intake and it will be welded closed...I only drive my truck in the summer, and it wasnt even plugged up this year and my engine hits on the first key turn...
    Oh yeah. Someone reminded me about the charcoal canister. It's there to absorb the vapors from the tank and they get released into the engine at various times of operation. Some people keep it. Some dont. I'm sure you guessed that I didnt. It's gone. My tank vents to the atmosphere. Cue the global warming theorists.....same story though. It can go. No ill effects.
    I hope you learned something!! Heres the pics!
    Erwin Merida and KERTWOOD like this.
  2. 1lowSr5
    1lowSr5 Addict
    In the garage
    90' xtra cab Sr5, 2003 taco
    Awesome write up! Wish I had the 22r/22re but I don't. I need to find one on the 3.slow. I'm sure most of the info here could also be used on the 3vze.
  3. Xs5875
    Xs5875 Addict
    Greenville, Ga
    Definitely..same concepts bro.
  4. Litneon
    Cocoa, FL
    94 xtra cab
    You copyrighted your engine pic? :)
    Anyway, I've never heard of the pinging issue from removing the EGR and related stuff. I also ran with mine like that for a while and never suffered any ill effects.
    I did however have some issues trying to keep the rubber plugs on the vacuum ports. They kept cracking, so I ended up filling the plugs with RTV to keep them from leaking and finally welded them all closed.
    I did keep the one port on the TB for the AC idle kick-up solenoid as I live Florida where AC is pretty much needed year round.
    Erwin Merida and jblaust like this.
  5. Xs5875
    Xs5875 Addict
    Greenville, Ga
    That's not my pic..A guy who covered our car show in November...That's his picture of my engine...I just haven't bought the file yet ;)
  6. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    So did you lighten up the tension on the air flapper in the AFM? I tried that placement in my wheeler and had issues with the rig running overly rich since the weight of the flapper added to the tension of the spring. I looked into it and it was a common issue when remounting the AFM down like that.
    Nice writeup, I've been yanking the junk off of re's for a long time now. I keep the fuel pressure regulator, charcoal canister, brake booster and pcv lines but the rest get yanked off. The only issues I've ran into was on the rigs equipped with a 2 or 3 wire egr plug and may throw a code. Also the efi will act like a carburetor in cold weather and raise the idle and bring it back down as it warms up. Other than those minor issues it works out sweet. :D
  7. Xs5875
    Xs5875 Addict
    Greenville, Ga
    I haven't noticed a problem with the flapper door angle....as far as the wired egr valves are concerned, when you unplug it the check engine light will come on. Easy fix just get a 10k ohm resistor from radio shack and jump the terminals in the plug. It fools the system into thinking the egr is still sending a signal and no check engine light will illuminate.
  8. 1lowSr5
    1lowSr5 Addict
    In the garage
    You have a few pics of this?
  9. Litneon
    Cocoa, FL
    94 xtra cab
    Just run the vacuum line straight from the regulator to any vacuum port on the intake. The rest of the lines and the solenoid that are in between the two can be taken off.
  10. 1lowSr5
    1lowSr5 Addict
    In the garage
    Like this?
  11. Xs5875
    Xs5875 Addict
    Greenville, Ga
    Nope. That vacuum port will only see vacuum if the throttle is open that far to expose that port. Im not as familiar with the 3.0 as I am the 22re. The intake itself sees vacuum all the time. Is there a fitting on the intake itself and not the throttle body somewhere?
  12. Xs5875
    Xs5875 Addict
    Greenville, Ga
    See part 23265? Run it there. Triple vacuum adapter
  13. Xs5875
    Xs5875 Addict
    Greenville, Ga
    Not the green arrow that's just a generic pic I snagged off google.
  14. 1lowSr5
    1lowSr5 Addict
    In the garage
    Got it, I drove it a bit today with it how I had in the pic. I put it to that one on the intake now. :waytogo:
    Wouldn't that section still have suction from the intake even though the throttlebody's not open? It's still getting suction from the intake at that point I would think.
  15. RAS671
    RAS671 Member
    I know this write-up was since the beginning of the year, but thanks BIG time! Everyone I asked about removing the EGR and all those wires on top of my valve cover told me "you need that for your ECU". Good to know I can finally rid those unsightly wires!
    Big ups man!
  16. Xs5875
    Xs5875 Addict
    Greenville, Ga
    U sure can. There will be ppl who say this or that. But it's your truck. Build it to be yours.
    jblaust likes this.
  17. 93_Toy_Mini
    93_Toy_Mini Addict
    Gardnerville, NV
    93 Reg Cab Pickup
    Great info and write up. I've been wondering about doing this to my truck.
  18. warbird
    warbird Member
    so this may be a dumb question....but i see a VSV for the EGR and PAIR and one for fuel pressure up in the FSM diagrams....which one is for the A/C? i removed all but the fuel pressure up one is that the one for the A/C? sorry i cant find a wire diagram that is clear..... (only the one in my chilton) where do i get a wire diagram? i figured the FSM that i got from a link on here would have it but no luck, i sthere a supplement i'm missing? if so anybody got a link?
    thanks
  19. Xs5875
    Xs5875 Addict
    Greenville, Ga
    The grey vsv is for the ac. And the vacuum lines go to the spring loaded valve threaded into the intake.
  20. warbird
    warbird Member
    thanks.... that means i would need to keep 2 VSV's then? 1 for the AC and 1 for the fuel pressure up? ....although every other FI vehicle i have owned the FPR goes straight to a vacuum source on the intake.... not sure why this one needs a VSV to to control raising the fuel pressure? it doesn't make sense to me.
