2025 Winter Work
Discussion in 'Maintenance/Repair' started by RetirementToy, Jan 25, 2025.
  1. RetirementToy
    RetirementToy Enthusiast
    Vallejo,CA
    1988 Toyota Extra Cab 2WD
    My winter work as completed, updated the stereo head unit, reworked some dash wires, changed the air compressors wires & changed from inline fuses to breakers.
    Got all back together the night before my right hand surgery . Had to move the truck out for a 2nd time as forgot to get the ice machine needed for my hand & in the rush I damaged the drivers door badly, sprung it!
    My doors are stock hing & stock latch suicided !I have over 40 hours in each door. I hope to save the door ,but just in case I found a stock door with my friend Ricky's help .
    If I have to replace it ,it will be a lot of work using the end places that I alrealy have changed on my door!
      File size:
      49.4 KB
      File size:
      49.4 KB
      File size:
      66.7 KB
      File size:
      57.5 KB
  2. RetirementToy
    Vallejo,CA
    With all this in front of me ,my hand in a cast till Jan 30, & my first show of 2025 , Forbidden Fantasy, a 9.5 drive for me. Lots to do in a short time, truck just not make the first show, but I WILL GO ANYWAYS!
    Erwin Merida likes this.
  3. RetirementToy
    Vallejo,CA
    Made some headway, made a cradle to make it easier to remove & install the door.
    The main dent is coming out pretty well, 2 cracks one at each side of the window post, a little welding & all will be good . 4.jpg 3.jpg 1 (2).jpg 5.jpg 6.jpg
  4. flacostaco
    flacostaco Toyotaholic
    Corona Southern Cali
    87 pickup
    looking good :waytogo:
    RetirementToy likes this.
  5. RetirementToy
    Vallejo,CA
    Started with the body filler, all I use is Ever Coat . First Metal 2 Metal, than Short Strand Kitty Hair, followed by Light Weight Filler 11.jpg 12.jpg 13.jpg 15.jpg
    redman likes this.
  6. RetirementToy
    Vallejo,CA
    Along with the door repair is hinge replacement as may have been damaged. And I forgot the bottom hinges at the body mount end had to be made thicker to space the door outward more. Also I had drilled 2 small 1/8'' holes once the doors were swinging correctly to locate the correct position while locking down tight by inserting 1/8'' rod.
    So I had to make a plate to drill those holes & a plate to weld to another plate to get the 5/16 '' thickness at welds to the hinge.
      File size:
      59.3 KB
      File size:
      1.6 MB
      File size:
      112.3 KB
      File size:
      86.9 KB
  7. RetirementToy
    Vallejo,CA
    ATTACH=full]24497[/ATTACH] 22.jpg Got the door repair work pretty much finished & hung the door for a test fit.
      File size:
      92.8 KB
  8. RetirementToy
    Vallejo,CA
    Now get the glass & wiring connected before Forbidden Fantasy in one week.
    Paint work will have to wait until July when no shows for me.
