2 viairs or a york 210
Discussion in 'Suspension/Chassis' started by stroked90hatch, Oct 12, 2012.
  1. stroked90hatch
    stroked90hatch Enthusiast
    Soo what's every1 think?....set up a york 210 engine drivin compressor or jus go wit the 2 viair electric compresors?.....
  2. Litneon
    Cocoa, FL
    94 xtra cab
    Twins can be obnoxious sometimes.... But so can a burned up compressor from lack of maintenance.
  3. yota4life
    yota4life Grand Toyotaholic
    lodi ca
    1991 xcab 2wd 4cyl
    I like my viairs never let me down but the speed of an engine driven Wud be nice just make sure you have a back up just in case
  4. Beefed Taco
    Beefed Taco Addict
    The only problem I can see with a engine driven pump is, if your engine has a problem somewhere in town and you need to have it towed, or put on a trailer, you won't be able to raise the suspension to get the clearance needed to get it on the trailer and home.
    This is why the old PTO winches and other goodies that ran off the tranny aren't as desireable off road because no motor means no wiinching, unlike sucking some juice from the battery or batteries while the engine is shut off to winch or fill air. I know these are worst case scenarios, but still something to consider.
    Isn't the York pump that really sweet huge one that costs an arm and a leg? I saw one at a car show a long time ago.
    btw..I use a Viair 450C on my 4x4 and it's been great, with the exception of taking a while to fill the 5 gal tank, but filling four 37" tires will do that. I'd love to add another, but that means another $250 or probably even more these days.
  5. stroked90hatch
    You can pick up a york at junk yards for around 50ish.....and autozone has reman for 175ish
  6. stroked90hatch
    I was prob gonna add one small 12v in back jus incase of worst case scenerio
  7. Under Construction '93
    Under Construction '93 Addict
    Riverside,Ca
    1993 Std Pickup
    I have 2 viair 480's and they havent given me any probs for over a year and fill my 7gal tank pretty quick too. Just my .02
  8. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    Beefdtaco your thinking of an oasis comp which those do cost like 2500-3000grand but they fill fast like an engine driven. But if you want engine driven look into sanden 708s or 508s with those you can do a grease conversion an don't have to worry about the damn oil. I have one sitting at the house tht I need to put in
  9. Beefed Taco
    Beefed Taco Addict
    Yep, you sir are correct. Is the York the ones ford uses?
  10. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    I'm honestly not sure I know a bunch of makes used the York
  11. stroked90hatch
    Mid 70s to mid 80s fords.....early 80 volvo 240...are best usually cause they already have the v belt setup....
  12. stroked90hatch
    Sanden grease setup would be nice but how reliable is it....grease breaks down under hear and does it always have too be torn down too regrease?
  13. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    From what I've read ppl use it a lot an its pretty reliable. With the York your still going to have to oil it every few days an need an oil water separater/inline oiler. Which cost rises. Grease conversion you just had every few months and you use a high endurance grease. Ill look up the one this Guy used he said its the best he's found so far
