1986 Xtra Cab Daily
Discussion in '1984-1988 Build-Up/Project Threads' started by Justintheegreat, Jun 20, 2020.
  1. Justintheegreat
    Justintheegreat Member
    Bay Area CA
    1986 Xtra cab
    Just picked up a 1986 Xtra cab 22RE
    Seems likes it's been a California truck its whole life.
    Its my daily from the valley to the bay area.
    So stay tuned.
    Instagram @justintheegreat_outdoors
    Erwin Merida likes this.
  2. Justintheegreat
    Bay Area CA
    1986 Xtra cab
    Ordered the wrong window regulators so if anyone needs 2 manual window regulators WITHOUT wing/vent windows you can have them.
  3. Justintheegreat
    Bay Area CA
    1986 Xtra cab
    replaced both window regulators and added some true glide to all moving parts as well as inside the window channel rubber.
    so much better and smoother
  4. Justintheegreat
    Bay Area CA
    1986 Xtra cab
    Just picked up a Solid back window for the Xtra cab.
    and instaling my lowering kit from Belltech.
    stay tuned for pictures.
  5. Justintheegreat
    Bay Area CA
    1986 Xtra cab
    Installed Belltech Lowering spindles.
    As well as the Ball joint flip.
    Now my lower control arms are rubbing on my inside lip of the wheels.
    May have to add a spacer
  6. MrDinkleman
    MrDinkleman Addict
    SoCal
    1988 standard cab, long bed
    What size wheels do you have? I want to install the lowering spindles so I need to know what size wheels to plan for.
    TIA
    Justintheegreat likes this.
  7. jetas
    I think for drop spindles PLUS a BJ flip you cant run anything smaller than 16".
  8. MrDinkleman
    MrDinkleman Addict
    SoCal
    That's good to know. I don't plan to do the ball joint flip and plan to use 16s. Didn't see any decent 15" tires in 205/60 or 215/60 sizes...
    I'm thinking of using the flat face, 16x7 Supras, with 37mm offset. I THINK they bolt up but I need to test fit it...
  9. Justintheegreat
    Bay Area CA
    1986 Xtra cab
    Yup. Learning that. My wheels now rub on my lower Control arms at full lock.
    So im going to see if these 15" wheels will fix the problem. If not gonna add some spacers or grind them down to clear my wheels.
  10. Justintheegreat
    Bay Area CA
    1986 Xtra cab
    Hopefully these work.
    Still deciding on tire size.
  11. Justintheegreat
    Bay Area CA
    1986 Xtra cab
    Currently running these turbo wheels 14"
  12. Justintheegreat
    Bay Area CA
    1986 Xtra cab
    Next on the list is interior:
    - New carpet
    - New dash pad.
    - Outter window sweeps
    - Attempt to kae the shelf in the rear for the Xtra cab
  13. Justintheegreat
    Bay Area CA
    1986 Xtra cab
    Enjoying this thing.
  14. Justintheegreat
    Bay Area CA
    1986 Xtra cab
    Got my solid glass installed.
    OEM toyota
    Erwin Merida and jetas like this.
  15. jetas
    Solid bad windows are so much cleaner looking
  16. Justintheegreat
    Bay Area CA
    1986 Xtra cab
    Definitely.
    Less noise as well.
    Has some small scratches here and there. But not bad.
    Easy to install.
    jetas likes this.
  17. macawilial
    macawilial Veteran
    Born and raised in San Diego
    I like! Yep, looks cleaner. Less lines. Plus solid windows are good theft deterrents.
  18. Justintheegreat
    Bay Area CA
    1986 Xtra cab
    Indeed.
    I think I need to remove my inner wheel wells.
    These tires rub and burned them through. Haha
  19. Justintheegreat
    Bay Area CA
    1986 Xtra cab
    removed my inner plastic wheel wells. shaved my rear bum stops maybe 2" and the fronts about 1"
    i rub pretty hard when hitting bumps in the road or turning too hard.
  20. Ausjohn
    Ausjohn Newbie
    Melbourne, Australia
    84 Xtra cab 4x4 & 85 Xtra cab 2wd
    I love the sliding rear window! It wasn't an option here in Australia, I'd happily fit one to mine, if you fancy posting your old one over here??? :p
