I hate to sell it but just seeing if anyone is interested, I have a 1986 Toyota Pickup fully built from ground up. A lot of modifications and goodies in it has a 22r motor, brand new tires and rims, custom fuel cell, comes with extra Toyota EFI wheels and extra stock block, Just need to finish interior all complete just needs reassembly took apart for wire tuck and paint LC Engineering Spec Stage 5 Pro Stroker long block 50 Mikuni/ Solex side draft carbs Cannon aluminum powder coated intake motor is 12.5 to 1 comp CP Forged Pistons with racing rings Eagle forged connection rods Pro Stroker crankshaft 22R Race prepped head 5 angle valve grind port and polished port matched to intake titanium valves dual valve springs Custom grind Schneider cam .527 lift dual timing chain conversion Block bored .80 over Powder coated valve cover LC Engineering polished 5 inch water pulley LC Engineering pro oil pump with adjust pressure ARP Head Studs MSD Full Ignition MSD wires MSD Ignition Box MSD Blaster 2 coil MSD 3 Stage Retard controller NGK Race Plugs Nitrous Sportsman Fogger with jets 50,75,100,125,150 10 LB Nitrous botle 9 LB Flywheel ACT 6 Puck Clutch disk ACT pressure plate Toyota 8 inch rear with 4.38 gears Full 8 inch spool, not welded 94 transmission Custom built fuel cell and battery bracket relocated rear for weight transfer 7-15 PSI fuel pump with regulators Complete wire tuck from in the truck, a lot more to mention but just to give you a rough idea of what everything is worth, spent well over the amount asking, truck runs and drives, have clear TX title in hand, needs repainted never got to it yet, and a new windshield, can start truck for you and test drive around the block if serious..no Frauds, No Scams, No certified checks,
The engine alone is worth the price!! I have a stage #1 Pro Street EFI, with all they recommended, it was around $5,000,parts only!! Calif is a no go above the stage #1!!
how much for the efi wheels? if it s a good price, i'll go get them myself on my days off. i assume you are in TX since you said clear TX title.....
