1985 E Brake light stuck on?
Discussion in 'Interior/Electronics' started by Leftnut85, Jul 29, 2015.
  1. Leftnut85
    Leftnut85 Newbie
    I have a 1985 single cab 4 speed. Just rebuilt the motor and fixed some of the light bulbs. Started driving it to work to save some gas. How do i get the e brake light to turn off? I pull the handle twist and push into the dash to dis engage brake but the light never turns off? Another thing is the tach for the mph has a loud tick to it and kinda jumps around. How can i fix that?
  2. LilRed93
    LilRed93 Addict
    Spanish Fork, UT
    1993 Pickup
    I know on my truck I have to turn my handle one way a bit to get mine to shut off. A little querk my E - brake has.
  3. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    There is an electrical switch about 8" inside the dash that you can see looking up at the handle. Make sure it's plugged in. If i remember right if it's unplugged the light won't go off.
  4. Leftnut85
    Leftnut85 Newbie
    Okay Thanks. Ill look for that under the dash when i get home tonight. Anyone know about the MPH tach? How to fix? i dunno if i need the whole gauge setup or maybe its just a little gear?
  5. White Trash
    Eastern WA
    The speedometer cable is most likely just gummed up. If you unhook it at the transmission you can pull the cable out of the housing and clean the old grease off of it then relube it with chain and cable lube before putting it back in.
  6. jmich2001
    jmich2001 Newbie
    The brake fluid on my 87 was low, topped it off and light went out.
  7. YOguyDA
    YOguyDA Addict
    Sacramento, CA
    1986 Regular Cab
    Good point!
    There is a float sensor in the cap of the master cylinder. Should b a pigtail/plug coming out of that.
