1975 20R water pump without a extra hole in the middle
Discussion in 'Engine/Drivetrain' started by OMI, Dec 18, 2013.
  1. OMI
    OMI Newbie
    1983 Toyota Pickup SR5 4X4 Short Bed 22R
    Hello I have trouble finding a water pump for a 20R engine with 8 screw holes.
    I search in autozone and Oreilly and they only have water pumps that have 9 holes. Where can I locate one with 8 holes? Is the 9 hole only for the 22R?
    Because I tried installing one and it looks like that water will get out.
  2. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    You could swap cover plates or silicon the extra hole shut. Ill have to see what mine runs. Never knew there was a diff.
  3. first80toyota
    first80toyota Addict
    Pacific Northwest
    '77 Hilux
    Or instead of silicone, tap it and put a pipe plug in it..
  4. OMI
    OMI Newbie
    Used JB Weld to cover the extra hold
    Thanks for the replies it was helpful.
    I was looking and researching a bit more I could not find a similar replacement. So I covered the extra hole with JB weld and it seems to work. I let it cure all night and it is now solid. I already put it on and took it for a drive for the last 4 days and everything it fine, no leakage or overheating.
    I am still wondering is the 1975 Toyota 20R the only year that has 8 screw holes for the water pump or does it continue until the 22R. I noticed in most auto part stores list their water pumps as 20R and 22R compatible. which was weird.:shrug:
  5. Jim Thompson
    Jim Thompson Member
    I know this is an old thread but I am finding that 77 -85 20 r and 22r waterpumps are the same, 75 76 are different
