Discussion in 'Suspension/Chassis' started by yotaman95, May 12, 2013.
  1. yotaman95
    yotaman95 Enthusiast
    Cottonwood Heights Utah
    1995 single cab
    So I finished my Beltech drop spindles, shocks and anti sway bar. I also got it aligned but now my drivers side sits about 1/2 in. higher than my passenger side. I am pretty sure it is that my torsions are out of wack. Will it throw it out of alignment if i loosen one side to get it to sit level? Any help would be prime fellas.
  2. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Give it a little adjustment on that side . I wouldn't worry to much on the anligment if it even changes at all it proably would be very mininmal .with no side effects
  3. yotaman95
    1995 single cab
    cool man. thanks ill give it a go
  4. Turbo Blow Through
    Turbo Blow Through Addict
    austin tx
    87 hilux
    Sit in it that will fix it. Ever had a vehicle aligned and adjusted with you in it? That's race sh!*#...!
  5. Da_Roach
    Da_Roach Toyotaholic
    NOVA
    (1) 92 RN80 (1) 2002 RZN150
    Gas tank could also be the reason if your talking about the back of the truck.
  6. yotaman95
    1995 single cab
    It is the Front but it is better when i sit in it but not perfect. Big O charged me a pretty penny for my alignment cause my tie rods were to long so they had to trim them and add camber shims. So ill just make them get it perfect haha
  7. topcop182
    topcop182 Addict
    Colorado Springs Colorado
    1993 single cab 2wd
    firestone had/has a 125.00 lifetime alignment deal, you should check into. Secondly, the truck will settle a little bit as time goes on. As for it being grossly different, check torsions!
  8. yotaman95
    1995 single cab
    It's not crazy off it's little less than 3/4 in. So I am hoping it's the new shocks and spindles an it will settle out. And I am pretty sure Big O has a year or two warenty. Also got a friend that works there, so I'm chili beans!
  9. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Then just leave it and wait a couple months and see how it sits
  10. Malessohomegrown
    Malessohomegrown Toyotaholic
    Malesso,Guam
    tortion
    Yeah you gotta drive it around and let it settle.Then make adjustments.
  11. yotaman95
    1995 single cab
    Thats what i am thinkin. How can i go lower other than bags or loosening my torsions? Just curious
