I was wondering if anyone would help me with wheel size, I am fairly new at this so I need a more experienced opinion. I am going for a flush or tucked tire look will the 15x8 with 4in backspacing have any issues or should I get 15x7. Thank you so much
That'll depend on the year of the truck. What's the backspace of the rims you have, and how wide are they?
Take one off and measure (look up on Google if you're not sure how to accurately measure). Also measure the rim width. Otherwise, I'm just making educated guesses, and can be wrong.
I'm running 16x7. I needed 5/16" spacer and extended studs due to the dust cap on the front spindle. Rear fit without issue. stock bore/hub is 67.1mm btw. It cleared everything. I'm running drop spindles now and that also works. Wheels: https://www.hubcaphaven.com/p/933/aly9026-jeep-cherokee-wheel-painted-5gr08trmaa.html Extended studs: https://www.summitracing.com/parts/RNB-610-463
