Hey gang, I saw some 90/130w H4 headlight bulbs and it got me thinking . . . Can I just pop those babies in and be good to go? Or would I need to do some heavier wiring or something? Thanks!
I'm guessing you should be good. Even at 130 watts with a low voltage of 12, you are still only around 11 amps of current. #16 wire can handle that easily and I believe the wiring to the headlights is at least #14 which is typically good for 15 amps. You may run into a fuse size issue though....
Thanks, Litneon! Twizted, I got a set of these: NARVA H4 130/100 WATT RALLY/OFF-ROAD BULBS USA SELLER : eBay Motors (item 130453432860 end time Nov-16-10 13:53:58 PST) Also, check this deal!! SUPER BRIGHT 10 PACK HALOGEN H-4 H4 90/100W HEADLIGHTS - eBay (item 110427457110 end time Nov-16-10 19:06:15 PST)
I've read a couple different things. One guy said both hi and lo beams were white. Another guy said his hi beams were white but the lo beams were very yellow-ish. I'll let you know!
