aftermarket speedometer and gauges ?
Discussion in 'Interior/Electronics' started by V8_TITAN, Oct 10, 2010.
  1. V8_TITAN
    V8_TITAN Toyotaholic
    Tampa Fl
    89 std cab
    ok well Im thinking about ditching my gauge cluster for a nice clean looking setup, since my speedometer barely works anyways I would like to replace it..along with all mechanical gauges like fuel,water temp,oil temp, oil psi and other crap...which I know how to do since I already have most of them.. but how do you add an aftermarket speedometer ?!?
  2. Sound.Vision.Soul
    Sound.Vision.Soul Toyotaholic
    Ottawa, Canada
    93 Pick up I6 Turbo
    I believe what everone you get comes with the adapters to hook it up to you cable... but if its electric then im not sure.....
  3. kamesama980
    kamesama980 Addict
    Columbus, IN
    91 Base
    didn't you just post a thread about how you couldn't afford a $14 oil pump o-ring? aftermarket speedos are $100+. usually +++++ then you have to make a custom panel to fit your new gauges
    oil, temp, etc are all electric gauges from the factory BTW.
  4. V8_TITAN
    Tampa Fl
    89 std cab
    thats what I thought, wasnt sure though.
    I know I dont have money for this right now, but Id like to know what im doing before I go order the parts and realize oh sht this is a lot more detailed then I thought !.... I know how much the speedo is and I already have all the other gauges... and im not interested in dummy lights, I want actual numbers like oil psi and water temp in degrees, not a red mark on a line...
  5. TRUCK ACTION
    I run all AutoMeter gauges.
    Here's the company & part you need:
    Speedometer Service Co.
    414-463-6661
    adapter for Toyota trans mechanical
    drive to electric
    #HE22C ,was $92.50
    ask for Roger, I got this back in 03
    :cool:
  6. twizted1
    twizted1 Addict
    NORCAL
    '89 xcab 2wd
    would like to see pics of the gauges you run...thanks.
  7. V8_TITAN
    Tampa Fl
    89 std cab
    thanks, Ill probably just order the adapter from him, or at least get a part number and find it cheaper on ebayyyy I do wanna see pics of your dash, havent seen it in a while.. actually no pics of your truck in a long time either???
  8. TRUCK ACTION
  9. TRUCK ACTION
  10. TRUCK ACTION
  11. TRUCK ACTION
  12. V8_TITAN
    Tampa Fl
    89 std cab
    oh sht you got the electronic speedometer, and all the sensors.. thats not gunna work for me, my I got a cable driven w58
  13. TRUCK ACTION
    My stock speedo was cable drive,the adapter goes right into the trans where the cable was! And it will work with any after market electric speedo!
    All the other gauges are mechanical /with the senders from Autometer (yes they must be wired) I spliced into the stock wires, all corrections are soldered & shrink wrapped, using the same gauge wire as stock!:cool:
  14. twizted1
    twizted1 Addict
    NORCAL
    '89 xcab 2wd
    wow...nice setup...looks sooo clean!!
  15. V8_TITAN
    Tampa Fl
    89 std cab
    how do you adjust it ???
  16. TRUCK ACTION
    There's a set way to calibrate it, very easy to do .
    This is the speedo:cool:
  17. V8_TITAN
    Tampa Fl
    89 std cab
    thanks.. if I order this and end up pulling my hair out from my head... your gunna have some explainin to doo !! haha
  18. Raffaelli
    Raffaelli Toyotaholic
    Houston
    82 Longbed 2WD
    Hey Action, could you post a link to that adapter,(or one like it)
    Thanks.
    BTW, nice clean harness you made. I know it takes way way too much time doing it the right way.
  19. joeynational
    joeynational Toyotaholic
    PHX,AZ
    91 2WD
    couldnt you just use the trans adapter from an electric drive Toyota speedo? They are the same except one has an electrical plug and the other is threaded for the mechanical cable..
  20. V8_TITAN
    Tampa Fl
    89 std cab
    IDK wanna be the first ? haha
