Tilt bed?
Discussion in 'Suspension/Chassis' started by Litneon, Jul 5, 2010.
  1. jeremystephens
    jeremystephens Enthusiast
    mississippi
    94 xcab
    i put my fuel cell under the raised bed floor so i do have to raise to fill up anywayz here's a few pics anything else i can help with let me know
  2. Litneon
    That's pretty simple, I like it. Now you've got me thinking...;)
  3. skip
    skip Enthusiast
    Utah
    1992 std cab, 1986 std cab
    I would like to see how you are latching the bed down so it doesn't bounch around while driving. I've seen too many trucks with tilt beds that bounch while they drive because they aren't latched down.
  4. humanmachinehead
    humanmachinehead Member
    Hickory NC
    ditto, I'm curious as well. I thought about just using a bear claw latch tho
  5. keckert
    keckert Newbie
    Regina, Saskatchewan
    1989 v6 xcab 2wd pickup
    Why not just use a trailer hitch pin that holds a mount from the front of the bed to a mount on the frame?
  6. IronNam
    quick detach or just relocate
  7. yota4life
    For a latch use a bear claw an like a pull cable or a door solenoid
  8. six7one_KDR
    six7one_KDR Veteran
    From Thee Island of GUAM,Live's in WASHINGTON / NO
    1976,1979,and also YES a 1973 HILUX
    OLDSKOOL DUMP BED set up
  9. Beefed Taco
    Beefed Taco Addict
    I dig 'em! Question though...does the bed have to mounted slightly back so when it comes up the lower area on the front won't hit the cab? Or does that not change when tilting? Nevermind, just took a ruler and a book and checked, seems it doesn't change.
  10. WDE_BDY
    WDE_BDY Member
    New Zealand
    1981 Toyota Corolla minitruck
    Yeah, clearance will depend on the pivot point. As long as it is close to the level of the bottom front edge of the tray then you should have plenty of clearance from the cab as it swings up.
    Callum
  11. _toph_
    _toph_ Member
    Lake Jackson, TX
    92 xcab
    The further back you make your fulcrum point the more clearance youll have
  12. boner.too
    boner.too Enthusiast
    Guam
    1994 single cab
    these pics seem familiar? paseo again frieday?
  13. Litneon
    Getting the gears turning, I have a set of air cylinders looking for a home...
