Ah! what the hell?
Discussion in 'Engine/Drivetrain' started by DROPT, Sep 13, 2010.
  1. DROPT
    DROPT Addict
    Whales Vagina
    So i was going to adjust the valves today because the truck has over 200k on the clock. so i read up on it, thought i knew what i was doing so i pulled the valve cover off. then i realized i didn't know what i was doing so without messing with anything i put the valve cover back on etc.
    NOW! the damn thing will not idle and wont even start without me giving it some gas. its carbed btw not efi.
    Why would the idle be ****ed now? all i did was disconnect the throttle cable to remove the valve cover but that shouldn't have messed it up.
    Someone tell me what went wrong lol i kinda need to get it out of the garage since i'm in my mothers parking spot.
    also can i get some insight on valve adjustment as far as finding tdc
  2. DROPT
    DROPT Addict
    Whales Vagina
  3. dillinja666
    well wait...
    first off you dont need to know tdc to adjust the valves.
    second did you put all the vaccume lines n crap back, if you have a stock 22r there is a mess of junk underneath the air cleaner.
    i would take the air cleaner back off and double check everything.
  4. DROPT
    DROPT Addict
    Whales Vagina
    dumbass me forgot to hook up the line that goes to the pcv :verdict_in:
    so its best to adjust valve lash with a warm engine? i hear most people say do it when its warm, then others say cold
  5. dillinja666
    adjust em hot! like run it on the freeway then get home and adjust em. You are gonna have to do it fast too cause if it really starts to cool the last adjustments may be loose and noisy.
  6. oahu grown
    oahu grown Toyotaholic
    Hawaii
    92 Extra Cab
    How do you adjust the valves? And is it the same for all R series engines?
  7. dillinja666
    actually the specs are the same for the 22r and 22re...
    .008 intake
    .012 exhaust
    there are all these werid directions online about adjusting them. the easiest way i do it is adjust all the valves that are not on the enlarged side of the cam lobe...so basically all valves that are on the base lobe, then turn the motor a bit and adjust the rest that were not on base lobe, keep doing this until all valves adjsuted.
  8. thundering02
    thundering02 Addict
    Fenton 63026
    always adjusted the hondas when warm .. let it run in the driveway a bit adjust the loose ones .. turn ninty degrees adjust the loose ones..turn adjust etc....
  9. joeyota653
    joeyota653 Enthusiast
    this is how me n my grandpa did ours.. but we may have been off on the spacing!
    now my trucks rattling around! hope its the valves
  10. Raffaelli
    Raffaelli Toyotaholic
    Houston
    82 Longbed 2WD
    Adjust mine cold at 7-11.
    Quiet as a BMW. :waytogo:
    TDC is irrelevent if you know what to do. Just make sure your off of the cam lobe for each valve as you go.
  11. dillinja666
    they are not supposed to be quiet quiet....this valve train is loud...check your running vaccum, if you did it right it should be over 20 inches. if not your vaccum will be low. like 18 or so, tight valves will make your motor not as efficient.
  12. DROPT
    DROPT Addict
    Whales Vagina
    so i adjusted them today got it good and hot, they were all tight. now its louder than a mofo it sounds like a diesel
