transmission question.....
Discussion in 'Off Topic' started by duckyaz, Mar 11, 2010.
  1. duckyaz
    duckyaz Veteran
    Pinetop, AZ
    can a toyota 2wd transmission be converted to a 4wd simply by unbolting the tailshaft and bolting a transfer case on? if not, is there any way to convert a 2wd transmission to 4wd?
  2. IronNam
    it'd be much cheaper to find a 4wd Toyota transmission
    or 4wd truck basically lol
  3. Nook
    Nook Addict
    oregon
    No, you can't simply change the tailshaft, the 4x4 trans uses a shorter mainshaft, to convert the 2wd trans would require changing the main shaft, then using a 4x4 tailhousing that made to bolt to the transfer case.
  4. duckyaz
    duckyaz Veteran
    Pinetop, AZ
    how hard is changing the main shaft? i have a 4wd transmission and transfer case that is shot.
  5. SD YOTA
    ummm..... to be honest man you'd be saving yourself allot of headache, time, and whatever other involved effort by just finding a good 4x trans. its doable but to just about anyone its not worth the effort involved.......
    if you are really in need of a trans, you should look around out here in cali for a deal on one..... usually see em on craigs for anywhere from 50 bucks and up.....
  6. duckyaz
    duckyaz Veteran
    Pinetop, AZ
    well my 2wd tranny is the a340e and my 4runner tranny is the a340h. what all has to be done to swap the main shaft since that's what i have to do?
  7. dillinja666
    If you feel ok with taking this apart....:waytogo:
  8. IronNam
    I hate autos, with a passion :D
  9. duckyaz
    duckyaz Veteran
    Pinetop, AZ
    but how would i go about it. does anybody have any experience with it or is it all heresay? does anybody actually know how to go about it?
