Fusible link blown?
Discussion in 'Interior/Electronics' started by Boonies, May 23, 2023.
  1. Boonies
    Boonies Member
    Vermont
    74 short bed, gnarly tired Hilux
    Started the truck(manual) in gear but without the clutch depressed like a dumbass. Now the power is dead though the fuse box isn’t blown + battery has 12.8 volts. Figure I blew the fusible link pictured on the wiring diagram. Question, is this connection the fusible link and if so what should be used to replace it.
  2. fred heath
    Clean and retighten your battery connections. It takes a major short to melt a fusible link. Not by simply trying to start the truck in gear.
    Based on your battery picture, try that first. Terminals are really nasty.
    _Quickfox likes this.
  3. _Quickfox
    _Quickfox Enthusiast
    Yeah, check grounds, very important. May need new terminals, battery cables and build nice new ground wires engine to body and battery negative to body and engine, check out that and starter wiring...
  4. Boonies
    Boonies Member
    Vermont
    Thanks I’ll give them a clean and see if that resolves the issue.
  5. Boonies
    Boonies Member
    Vermont
    What’s the best way to test the battery ground and ground wires with a volt meter? Done a little electrical work but my knowledge is very limited
  6. fred heath
    Any wire that grounds to the frame should be cleaned up.
    On my truck, if you follow the negative wire from the battery to the frame you’ll find a common junction of wires. Clean them all really well.
    If you can twist your battery terminals by hand, they’re too loose.
  7. _Quickfox
    And he means clean the contact the grounds make, unbolt lug at the other end of the cable from the battery negative, wire brush the bare metal it contacts, somewhere on engine.
    At the back of the head there is another wire bolted to the head and the trucks body, this one usually needs replaced/uprated.
  8. Boonies
    Boonies Member
    Vermont
    Thanks and I’ll check for the head ground . Went ahead and made a new ground strap that connects to the - battery terminal, radiator, engine mount and engine. I’ll clean up the points that mounts to and see if they fixes the issue.
    Any more suggestions are always appreciated
  9. Boonies
    Boonies Member
    Vermont
    Thanks for all the help guys. It ended up being the ground strap which was one of the easier fixes.
