1977 Toyota Hilux fuel line
Discussion in '1976-1983 Build-Up/Project Threads' started by sixpointsixv8, Apr 5, 2022.
Tags:
  1. sixpointsixv8
    sixpointsixv8 Newbie
    Pocatello Idaho
    1977 Toyota Hilux
    So I bought a 1977 Toyota Hilux and have a rusting fuel tank along with metal lines. I’ve tried looking on Napa, Autozone, ect and cant find a fuel tank that looks similar. The one I have is more rounded and egg shaped with two holes on the topside along with the one hole to out gas into it. Im also having problems with the metal fuel lines rusting too. Anyone know any stores or ways to fix this?
  2. Perkolator
    Perkolator Toyotaholic
    Placer County
    1975 Hilux
    Most auto parts stores sell universal parts for metal fuel/brake lines and you can rebuild the system yourself. Gas tank, I'd likely go aftermarket fuel cell vs trying to source something specific to these old trucks.
    David Eidson likes this.
  3. Pearce
    Pearce Toyotaholic
    Washington
    1973 hilux
    You can find one dude on Facebook that sell parts out of Thailand for these trucks. I've seen him selling a gas tank before. You can get stainless fuel line and its pretty inexpensive. Hard to flare though. Not really necessary for a low pressure system.
  4. Toyotashack
    Toyotashack Enthusiast
    Monroe, WA
    77 hilux 92 2wd 89&90 runners
    I put a 87 pickup tank in my 77. Cleaned it out best I could. Pulled the in tank pump out. Ran new rubber gas hose from that tank to an inline pump and to the carb. No rust. Clean gas. I had to make some simple flat brackets to get the tank to bolt up. It might fit perfectly on a short bed.
    Perkolator likes this.
  5. jetas
    where are you located? I have the tank out of my 72 that might fit
  6. sixpointsixv8
    Pocatello Idaho
    1977 Toyota Hilux
    Im out in south-eastern Idaho. I might have to try what toyotashack has recommended.
  7. sixpointsixv8
    Pocatello Idaho
    1977 Toyota Hilux
    Might be worth a shot. I kind of came to the conclusion that id have to jimmyrig something together.
  8. jetas
    Shit i was guna say you can have my old tank if you were willing to pick it up.
    you can always switch over to a fuel cell or like said above, made something newer fit
  9. David Eidson
    David Eidson Member
    also ask from its previous owner may be he knows something better.
