w50 slave cylinder return spring?
Discussion in 'Engine/Drivetrain' started by Henry, Jun 27, 2020.
  1. Henry
    Henry Enthusiast
    Washington State
    The w50 (5 spd) is installed and I'm finishing up a few things. I reinstalled the slave and went to attach the return spring but I don't see an obvious way to attach this. I only have the 4 spd spring and figured it should be the same. Am I missing something? Is it possible this slave doesn't use the return spring like the 4 spd did?
  2. fred heath
    My L43 has no return spring on the slave. Everything is hydraulic.
  3. Liquidhandwash
    Liquidhandwash Enthusiast
    Northen VIC
    1980 diesel
    Some have a spring some do not, generally if they have a spring the pushrod will be adjustable
