C Notch
Discussion in '1984-1988 Build-Up/Project Threads' started by Jonathan0824, Apr 1, 2020.
  1. Jonathan0824
    Jonathan0824 Newbie
    Hey guys, i have an 87 pickup and i want to c notch it, its already on 5 inch blocks and i want to go lower, do u guys know any good brand/company to use?
    Mini notch or a full 8"-10" notch?
  3. Jonathan0824
    Jonathan0824 Newbie
    Just wanna lower it another 1”- 1 1/2” the axle is already hitting the frame
  4. Jonathan0824
    Jonathan0824 Newbie
    Ive been looking around but i cant seem to find any kits
  5. jetas
    Il suggest doing a mini notch that way you dont have to cut into the bed.
    Its going to be a universal thing, not many direct fit kits out there. Found a few on ebay for less than $70.
    are you on IG?
  6. Jonathan0824
    Jonathan0824 Newbie
    Ohh ok, yea im on ig, @johnnyyy_24_
  7. jetas
    if i find any on there il tag you.
  8. Jonathan0824
    Jonathan0824 Newbie
    Also, what did u guys do so ur driveshaft wouldnt scrape the crossmember underneath the cab
  9. jetas
    A lot of guys usually cut it
  10. Pearce
    Pearce Toyotaholic
    Washington
    1973 hilux
    I good way to do a mini notch is to get pipe with the radius you want and cut it in half. Then cut the frame for the pipe and reinforce. Brace the fuck out of it before you cut the frame and pull your measurements for reference. That type of notch it more acceptable to tweaking the frame when working because you cut a lot out. Unlike a full step notch that can be welding piece by piece to keep from tweaking.
  11. Jonathan0824
    Jonathan0824 Newbie
    Thx man, yea i just want a mini notch so my axle doesnt keep hitting the frame
  12. Jonathan0824
    Jonathan0824 Newbie
    Yea thats what i wanted to do but i just wanted to be sure it wasnt a bad idea
  13. Pearce
    Pearce Toyotaholic
    Washington
    1973 hilux
    Just throwing it out there a mini notch will be weaker the stock. Some engineer ran the numbers in a computer program. Make sure you box in/reinforce. If you do just a pipe it will be about 70% weaker. The step notch is the best way to not lose any integrity of the frame.
