Headlight upgrade options?
Discussion in 'Interior/Electronics' started by Henry, Jul 23, 2018.
  1. Henry
    Henry Enthusiast
    Washington State
    Looking to get a little more light. At the moment I'm running the stock 7in sealed beams headlights. I'm not sure if I would look into a fog light option for additional light or if there is a good alternative housing I could buy to get more light.
    Has anyone upgraded to the Hella housing, and H4 bulbs?
    https://www.amazon.com/dp/B001G76Q2W/ref=psdc_15730151_t1_B000FKIURK
  2. TRUCK ACTION
    I have ran Hella lens forever ,first used high end bulbs, than changed to HID bulbs with ballast, way brighter, & just in the last few months I changed to LED bulbs from the same supplier.
    Like them a lot, less heat from the bulb= longer life & 5,000 lumens. I always get 6,000 Kelvin which is very close to sun light,very bright white.
    The Hella lens focus the light beam better than most lens & are glass so will ever fog over. You can find them on amazon .
  3. jetas
    Ive heard alot of good about the Hella housings. Just dont put HIDs in them(housing scatters the light). LED bulbs maybe.
    The 7" LED headlights are looking pretty cool too. Not sure of the light output tho
  4. The Count
    The Count Newbie
    Any links to these upgrades? They aren’t so easy to find in the UK.
  5. Henry
    Henry Enthusiast
    Washington State
    The Hella housings?
  6. Henry
    Henry Enthusiast
    Washington State
    I would love to run HIDs on this truck, but I need to keep the cost down since I'm replacing a ton of other things. Anything over stock right now would be great.
  7. Henry
    Henry Enthusiast
    Washington State
    The LEDs are cool but I'm not sure how much better this would be over stock. Another option I was considering was finding some LED fogs that I could mount behind the grill.
  8. TRUCK ACTION
  9. TRUCK ACTION
    Their kit was around $65 with a life time warranty.
    I bought 2 kits so could just change out & send in .
  10. TRUCK ACTION
    Never saw that problem, light beam was well focused !
  11. TRUCK ACTION
    There is no comparison to a stock head light,period!!
    jetas likes this.
  12. Henry
    Henry Enthusiast
    Washington State
    As for the hella housings, what size fit our trucks? I see they offer three different sizes for the round housings. 135mm, 165mm and 173mm.
  13. TRUCK ACTION
    I would call them.
    My truck takes the rectangular ones,1984-1988
  14. Steve M Clark
    Steve M Clark Member
    Waynesboro Virginia,Shenandoah Valley
    1980 SR5 short bed
  15. TRUCK ACTION
    Had that problem,no high beam indicator, with my LED from DDM Tuning, called them, & there was an inline connection fix!
  16. Steve M Clark
    1980 SR5 short bed
    I tried many things to get my hi beam indicator light to work.I found adding an under hood light connected to the low beam light fixed it, it made no sense but it worked.
  17. TRUCK ACTION
    You can put a resister inline .on one side.
