i just did my swap and I noticed the connectors both have 3 wires but the 4Runner has a red/white, red/black and a red/green wires. And the 2wd has a red/green and the remaining 2 are both red/white. I'm going to hook up the dmm tomorrow but hope someone could help point me in the right direction in this. THANKS!
put that volt meter to use. one of them is high beam one is power. i believe red/white on 4runner is power which goes to our green/black. did you use the pickup rad core?
Sweet man thanks ALOT! I'll deff use it tomorrow thanks for the help. Yeah for now I used the 2wd core. Really not bad at all. Drill like 3 holes per headlamp and your in business
you gotta picture for the light mounts you did? cutting my core up tomorrow. make sure to check the currents with a volt meter if you have one.
well currently zip ties are holding it but you can put up the grill and lights and mark where you need the new holes to be. i needed to move my horn, it was in the way. if you still need pix i will take some. do you by any chance know what wires from the 4runner side go where? as far as power ground and high beams.
that would be awesome if you can get a pic, i just need how you did the headlights. also did you get the corners from the runner? my 4wd corners does not line up whatsoever with the grille. try this link: http://forum.ih8mud.com/threads/headlight-wire-harness-fj60-and-fj62.354712/ i only took a quick look at the diagram, had same wires so i figured theyre the same. ill put my voltmeter to my truck tomorrow though just to be sure. not sure about the 4runner ill find the diagram tonight.
