Rusted out floor pan ,aluminum or sheet metal
Discussion in 'Exterior/Body' started by Crosaga, May 23, 2016.
  1. Crosaga
    Crosaga Newbie
    Haiku,Maui
    1984 Toyota pickup
    So my floor pans are rusted out and need to be replaced. What I came up with so far was to either fabricate it out of aluminum and rivit it in or out of sheet metal and weld it in, seeing if anyone's got any better ideas or options would be good to
  2. Perkolator
    Perkolator Toyotaholic
    Placer County
    1975 Hilux
    Depends on your goals. Personally I'm one to do it right the first time - weld metal floor patches in. It'll just come back/get worse if you don't remove and seal off the bad steel, so if you're going through all that prep work already you may as well weld.
  3. Mikerocosms
    Mikerocosms Veteran
    New Mexico
    1990 22R Pickup
    Not to mention that you don't want carbon monoxide to be able to come in if you have any kind of exhaust leak. Be sure and seal it up good.
  4. mrhanky
    mrhanky Member
    1978 Sr5 (RN23)
    I'm debating the same thing with me 78. What about the guys that are patching small holes with old license plates? Mine is ratty and that would match the look.
  5. Crosaga
    Crosaga Newbie
    Haiku,Maui
    1984 Toyota pickup
    I've seen pictures of floor pans made completely of license plates. If you do plans on going that route I could send you some Hawaii plates to add in the mix
    mrhanky likes this.
  6. Perkolator
    Placer County
    1975 Hilux
    I suppose a license plate will work if you're gonna surface mount it and want it visible for that type of look. Personally, I like having carpet installed in my trucks and no obstructions when I slide my foot around in the cab floor.
