Size socket to remove exhaust flange at Manifold
Discussion in 'Engine/Drivetrain' started by 22R88, Jan 21, 2016.
  1. 22R88
    22R88 Veteran
    South Louisiana
    1988 Reg Cab Deluxe RN50
    There are three nuts and the 14mm is too small. Is it a 15 ? I don't have one so I want to buy the right socket. A 9/16" is close but I don't want to round off the edges. Help appreciated.
    1988 22R 5 speed reg cab
    thanks,
    22R88
  2. Perkolator
    Perkolator Toyotaholic
    Placer County
    1975 Hilux
    Most Toyotas an be completely disassembled with a 10mm, 12mm, 14mm, 17mm, and 19mm.
    IIRC the correct socket for the manifold bolt head IS 14mm, so if its not fitting I dunno.
  3. 22R88
    22R88 Veteran
    South Louisiana
    thank you I will double check in the am....
    22R88
  4. 22R88
    22R88 Veteran
    South Louisiana
    It was 14... I had the wrong socket and couldn't see the 12 on the side....old age plus vision. You guys enjoy youth and hope you are around long enough to start losing good health :love:
    Thanks
  5. Perkolator
    Placer County
    1975 Hilux
    One reason why I love my cheap Harbor Freight sockets - they're colored/anodized and are 6pt instead of 12pt. Very easy to find the right size once you get used to which is the 12mm and 14mm, my two most used sizes on a Toyota. My nicer more expensive Craftsman set barely has any wear on them, go figure.
