Looking for Reverse light wire under the passenger seat
Discussion in 'Interior/Electronics' started by jblaust, Jan 12, 2016.
  1. jblaust
    jblaust Veteran
    Miami, FL
    I have a 1994 pickup Base. Im looking for which wire is the reverse wire on the harness under the passenger seat. I need to tap into it for my double din head unit to switch to video mode when I go into reverse for a back up camera. Any help would be appreciated.
  2. White Trash
    Red with a black stripe.
    jblaust likes this.
  3. jblaust
    jblaust Veteran
    Miami, FL
    Are we 3 for 3 now? I will let you know how it works out. Thanks
  4. jblaust
    jblaust Veteran
    Miami, FL
    Would it be the same color wire in the back at the plug for the rear lights?
  5. White Trash
    At the tailights and at the switch on the trans it's red/black.
    jblaust likes this.
  6. jblaust
    jblaust Veteran
    Miami, FL
    Your 3 for 3 now White Trash. Thanks for the help! I got my backup camera wired up to my double din now.
  7. White Trash
    Good to know you got it figured out.
    I've worked on a couple toyotas so I get lucky sometimes. :lol:
