soooooo the djm control arms i got where ****ty made and holes were off and the replacement bolt was to big and have given me a **** ton of extra work i did not want....... and now I'm completely stuck trying to get the torsion bars back in. idk whats up i greased em up and still got nothing the angle is not straight and withe the back torsion housing on first there is no way I'm very displeased with djm and as for the torsion i need help asap!!!!!!
I'd disconnect the lower from the spindle and the upper. Bolt the torsion back on. Run your bolt in a good way into the x member. Then using a jack under the lower jack it until the spindle can be re installed..
Yeah I had to drill the drill the holes on my DJM's to but besides that they're solid! Were you able to get your bars back on and adjusted?
