1978 truck 20R vacuum diagram
Discussion in 'Engine/Drivetrain' started by GRR78Hilux, Feb 21, 2015.
  1. GRR78Hilux
    GRR78Hilux Newbie
    Central Texas
    1978 Hilux
    I need some help, I have a 78 Hilux 20R and the majority of the smog / vacume lines have been removed. I need a diagram or some good photos so I can get this thinrunning properly.
    Thanks in advance for your help.
    Guy:brickknock:
    Do you have to smog it? If not just get a weber and some block off plates and strip it down to the minimum
  3. GRR78Hilux
    GRR78Hilux Newbie
    Central Texas
    1978 Hilux
    No I dont need to and I dont want to buy anothet carb. I have no problem with pulling all the smog junk off just want to use yhe original carb.
  4. jetas
    Search "20R Desmog" some good threads come up. Although everyone says tuning the stock carb is a pain to tune without the emmissions stuff
  5. first80toyota
    first80toyota Addict
    Pacific Northwest
    '77 Hilux
    On my first truck I ran a stock carb completel desmogged and tuned it just fine. If you know what your doing and your carb is in good shape, you won't have a problem. Just find the vacuum port on the carb that gets more vacuum with more throttle to run for the distributor
  6. GRR78Hilux
    GRR78Hilux Newbie
    Central Texas
    1978 Hilux
    Thanks guys, I took the smog pump off and I am in the process of replacing the base plate gaskets etc. I will keep you posted.
  7. static808
    static808 Member
    Vegas and hawaii
    1978 toyota pickup single cab long bed
    Weber 32/36 easier and better then stock IMO
  8. jetas
    Most of these carbed trucks dont have carbs in the best shape. Thats why i didnt even bother with mine. Ordered a weber right off the bat
  9. GRR78Hilux
    GRR78Hilux Newbie
    Central Texas
    1978 Hilux
    Had the header bypass ports cuto and welded closed. I have removed all the emisions except the EGR. I will be fabing a plate fir that in the next few weeks. Thanks guys for the advice.
  10. tyrap26
    tyrap26 Enthusiast
    why waste your time to fab plates.. order em there's kits on ebay and lce..
    very affordable.
