Wtb- 89-95.5 22re afm
Discussion in 'Wanted' started by B.Y.E., Apr 16, 2014.
  1. B.Y.E.
    B.Y.E. Toyotaholic
    "671" Houston, Texas
    1982 2wd Hilux
    Looking for a good used stock AFM. *The one i have currently has a dead spot when you whack the throttle quickly. It will rev out if gradually applying throttle but feels lean and sluggish... :eek:
    Tested E2 & VS pins and OHM readings start off fine but drops back down after halfway thru as the flapper door opens.
    Closed- 180
    1/4- 300+
    1/2- 500+
    3/4- 300+ (should be 600+)
    Full- 200+ (should be 1000+)
    Would prefer if OHM tested before i buy... :cool:
    Shootz!
    Ton
  2. SD YOTA
    have you checked the internals to see if something may have come loose..?
  3. Litneon
    You still looking for one? I have one right here.
  4. B.Y.E.
    B.Y.E. Toyotaholic
    1982 2wd Hilux
    SD- it appears previous owner opened it up and messed with it. Not sure where factory settings are so I got it set to best possible running condition I can... Lol!
    Litneon- pm me price with shipping to 77339... I may have a supra afm available if my buddy will let it go...
    Thanks!
    For the record, the AFM wasn't the cause of the bogging issue. But, since it's been messed with I'd rather replace it with an untouched factory one... :waytogo:
  5. Litneon
    Oddly enough, I don't know how to check on shipping estimates... a little embarrassed about that. I'd say I could ship it to you for $75. I'll test it ahead of time and give you pics of the meter readings. I'm not really sure what they go for, except that on eBay they are listed for between $99 and $150...
  6. SD YOTA
    gotcha. if neon cant send you his lmk. i have the supra afm in working order, and a 22re one coming up for sale soon. lol
