transmission wont go back together
Discussion in 'Engine/Drivetrain' started by patrickmashburn, Feb 15, 2014.
  1. patrickmashburn
    patrickmashburn Newbie
    springfield
    89 xcab
    Ok so I changed my flywheel clutch and pressure plate and now I'm trying to put the transmission back on and it will not go back together. Anyone have and little tricks or hints to help me get it back together? I've been at this since about 9:30 this morning
  2. White Trash
    Assuming you used the alignment tool on the clutch disc the issue is usually the input shaft not lining up with the clutch disc. I put the trans in gear and turn the output shaft while slipping the trans into place so it lines up properly.
  3. patrickmashburn
    springfield
    89 xcab
    now does it need to be in a certain gear or any?
  4. IronNam
    You have to tilt the engine.
  5. IronNam
    i leave it in neutral
  6. low_toyota92
    low_toyota92 Enthusiast
    Nashville, N.C.
    92 ex cab
    This may not help, but I hsd the same problem. Come to find out after hours of trying to get it together I called advance auto parts and had the check the part number and they had sold me the wrong clutch. After getting the right one from Napa auto it went back together very easy... Just throwing that out there.
  7. patrickmashburn
    springfield
    89 xcab
    thanks for the help I managed to muscle it back in and it finally decided to work with me.
