Tubular control arms
Discussion in 'Suspension/Chassis' started by suicidedyota, Jan 9, 2014.
  1. suicidedyota
    suicidedyota Member
    Independence ky 41051
    89 bagged yota
    I have a set that im about to install and suggestions or anyone know of any problems when doing this install?
  2. yota4life
    Where are they from?
  3. yota4life
    I know on my cando arms I had to use washers on the ball joint so the cotter pin would go through the castle nut idk how other arms are. And I used lots of anti seize on the lower conrtol arm bolt
  4. suicidedyota
    suicidedyota Member
    89 bagged yota
    They are from CANDO obviously bought them a while ago.
  5. yota4life
    Other than those things I mentioned theyre easy install and very nice
  6. suicidedyota
    suicidedyota Member
    89 bagged yota
    Thank you.
  7. yota4life
    No problem man
  8. suicidedyota
    suicidedyota Member
    89 bagged yota
    Im going to try to install them this weekend.
  9. 93_Toy_Mini
    93_Toy_Mini Addict
    Gardnerville, NV
    93 Reg Cab Pickup
    I bought the same ones from (formally CanDo) KBS Fabrication. I don't know if it's the same with all spindles but I also bought drop spindles and had to find spacers and grind off one side to make the spacers fit. Some advice for anyone else doing this would be to asked them for some extra spacers when buying their arms if you plan on buying drop spindles. The ones that come with the arms are a special item buy and not very common.
  10. suicidedyota
    suicidedyota Member
    89 bagged yota
    I haven't installed these due to I started body dropping mine I'll try to do a build thread here soon.
  11. 93_Toy_Mini
    93_Toy_Mini Addict
    Gardnerville, NV
    93 Reg Cab Pickup
    Are you doing a traditional bd or sfbd?
  12. suicidedyota
    suicidedyota Member
    89 bagged yota
    I'm going stock floor body drop.
  13. 93_Toy_Mini
    93_Toy_Mini Addict
    Gardnerville, NV
    93 Reg Cab Pickup
    Please post a link to the tread, I need ideas for mine. Not sure yet on where to start. I want to do a sfbd also.
