bagged truck guys
Discussion in 'Interior/Electronics' started by yota4life, Oct 9, 2013.
  1. yota4life
    My truck is bodied now an im test fitting the heater/defroster stuff an the right side doesnt fit anymore cause of my tubs. Anyone have pics of theres or what they did. Dont wanna lose this part of my truck but if I have to I have to
  2. Litneon
    Do you have pics? Of the firewall and parts you are trying to install...
    I modified my heater blower boxy thing, but my tubs aren't as large as yours have to be, I'm not bodied.
  3. yota4life
    Its the piece tht goes to the vent to the wiper cowl ill get some pics. It just hits my tub so it wont go in all the way
  4. Litneon
    With my blower box, I cut, sectioned out pieces, and epoxied it back together. I've heard of others doing the same to different parts, would that work? Basically plastic body work....
  5. NWA STEVE
    NWA STEVE Enthusiast
    missouri
    1987 toyota xtra cab longbed
  6. yota4life
    Heres the pics. I believe this the blower box?
    And heres the tub
  7. Lotoy
    Lotoy Enthusiast
    knoxville tn
    92 std cab
    I had to modify the mounting brackets a lil bit! I took the floor controls of the heater box! I will post a couple pics of mine! I basically just made some bolts instead of using the factory studs!
  8. yota4life
    Thnx man. Not in a rush to get this done just wanted to see if itd fit trying to get some ideas of what everyone else has done
  9. Lotoy
    Lotoy Enthusiast
    knoxville tn
    92 std cab
    Well here's mine! It's all in and all hooked up! I didn't modify the box at all except removing the floor controls and I'm tubd for 18s laying rocker! It does leave a small gap where the fresh air comes in from the cowl! I'm not really concerned with fresh air as long as I have defrost with a/c to keep my window from fogging up!
  10. Lotoy
    Lotoy Enthusiast
    knoxville tn
    92 std cab
    Tub
    Here is a pic of the tub
  11. yota4life
    Ya I just need defrost cause I plan on driving this alot. An fresh air wont be comin in much with a shaved wiper cowl
