I bought them, but the rims don't sit flush on the hubs, what is center bore on my truck and what is center bore on these rims? Any ideas guys?
You might need to unscrew that philips head on the outer surface of the rear drum.Alot of people running stock tacomas here.should be no problem.I had to do this to run my rims.I plugged the hole with some permatex.
Like he said about that screw, should do the truck. And what is on the front? Looks like something big and low offset.
these look like the 05+ tacoma wheels. thought they were off the 04 and prior... these may have a slightly smaller diameter bore, but not sure. they use a different hub/spindle combination style up front on the new ones. still im almost positive they should fit the older trucks. but the key point is that phillips head screw thats plugged into the drum face.
Great I will check, it was starting to get dark, good thing I checked could've been an accident waiting to happen, will keep you guys posted thank you all that chimed in.
This is what I'm rollin on now, I need run stocks as I plan to go so cal in few weeks to pick up some furniture and don't want to run on thin sidewalks.
Nice truck, can we get some more shots of it, maybe some side shots. and some once you get those tacoma stocks put on.
