Air-ride
Discussion in 'Suspension/Chassis' started by Loliffe, Jun 16, 2013.
  1. Loliffe
    Loliffe Newbie
    Gilroy,ca
    92 reg.cab
    Anyone have any links to air for these trucks.?
    I've done a suicide doors wishbone 5link on a Sonoma I used to own but have been away from any forums for a few yrs.
    Thanks
    Macon
  2. yota4life
    There's no bolt on kits for these trucks like s10s an full-size trucks. Everything is basically a universal cut to fit
  3. 93_Toy_Mini
    93_Toy_Mini Addict
    Gardnerville, NV
    93 Reg Cab Pickup
    Word... A weld on kit like this is what you are going to need...
  4. TRUCK ACTION
    Yes the above is what you should price out from all the suppliers you can find,comprise a list with part numbers & prices & go from there!
    The same will go for you fittings & valves,draw out what lay out you want & change on paper as you want ,make a list & start collecting parts ,in less you can get all @ once!!
    My advice on air tanks is go with stainless,you can paint or power coat if not wanted polished,but the inside contaminates will be only water, & the use of water traps in the set up will solve that problem!:cool:
  5. goukipu
    goukipu Newbie
    Ventura
    89 xcab 22r
    i have a 89 extra cab looking to bag it also i have a company saying the bags and bracket are 400 is that good i really dont want a super notch just a mild c notch
  6. jetas
    Bags and brackets arent all youre going to need. Link set up for the rear plus other chassis work. Its not a simple task. And sorry but a mild c-notch is good for static trucks not bagged. Do more research
