Smog pump question
Discussion in 'Engine/Drivetrain' started by john9280, May 4, 2013.
  1. john9280
    john9280 Member
    florida
    1990 toyota truck
    does anyone know if there is a smog delete kit for the 22r of how I can just run belt to a/c without running belt over smog pump
  2. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Don't have a smog pump but f u want to run a belt skipping it or if its removed .and in need of a short belt .. Either take a shoe string and loop it threw the pullies or. Zip ties and run to your parts store with your make shift measurement and troll threw the belts and find one that is short enough
  3. Tuhd The Troll
    Tuhd The Troll Veteran
    Houston, TX
    1982 SR5
    the trick most people who do this use is get some string and measure the length of the belt you would need if you didn't run it around the smog pump, and talk to your parts store or mechanic about getting a belt of that length which would be appropriate.
    ** wow, posted at the same time
  4. john9280
    john9280 Member
    florida
    1990 toyota truck
    @scrub88 did you have a smog pump and you removed it? can you post some pics of it
  5. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Lol tuhd I believe we were typing it all out at the same time .. To shay !!
    John mine is a 88 and only thing I have hangin off my block is a alternator . But if your into deleting it just remove it and its associated brackets and grab u a short belt
    I had a air pump same thing pretty much but I just got to I bolting everything ac air pump and all the brackets to clean it up if u have emission test don't remove it
  6. john9280
    john9280 Member
    florida
    1990 toyota truck
    theres no emissions in florida
  7. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Then u should be good just remove what you don't want keep note if vacuum lines are involved and cap were needed . And add the short belt good to go
  8. john9280
    john9280 Member
    florida
    1990 toyota truck
    just an update I took smog pump off and devaned it and its quiet as a mouse now basically it gutted and used as a idler pulley
  9. toy_spd
    toy_spd Addict
    So.Cal -
    92 SR5 V6 Extra Cab
    i need to move to a non smog state....
  10. kingtacoma951
    kingtacoma951 Addict
    CORONA,CALI
    88 SR5 Xtra Cab
    Me too!!!!!! Engine bay would look so much cleaner:D
  11. kamesama980
    kamesama980 Addict
    Columbus, IN
    91 Base
    Just throwing it out there that even without inspections, it's still illegal to modify or remove emissions equipment. I can hardly complain :D but just want to throw it out there that it's still breaking federal and state law. The only way it wouldn't is moving to a non-california emissions state and converting it to federal emissions (1 O2s, no EGR temp sensor, ECU, etc) Even then its a grey area.
    Just want to burst the bubble that you're all in the clear outside of emissions testing areas.:evil:
