93 4wd power steering for a 81 2wd ??
Discussion in 'Suspension/Chassis' started by KK5263, Feb 23, 2013.
  1. KK5263
    KK5263 Newbie
    Ontario Canada
    81 V8 283 / 200R4
    Hi guys
    I have a 81 2wd Toyota with a 350 Chevy that has no power steering. I've be given a 93 4wd, has anyone tried a 93 power steering into a 81. I'd like to do it this spring when I have the motor out. The parts are free but if its to much playing around I'd try looking for another doner car.
  2. Raffaelli
    Raffaelli Toyotaholic
    Houston
    82 Longbed 2WD
    I put power steer on my truck.
    Easy as pie. But a 2wd truck needs a 2wd p/s box.
    And depending on what year your motor is, it might be lacking 1 p/s pump bolt hole. Don't worry about it.
  3. KK5263
    KK5263 Newbie
    Ontario Canada
    81 V8 283 / 200R4
    Did you put in same year steering box or did you use a different year. I would have to come up with some brackets to adapt the Toyota pump to the Chevy block or try to use a Chevy pump and a Toyota box. Unfortunately 79 - 83 are a pretty rare thing around here. That's why I need a box from another year. If I had time I would like to put rack and pinion steering in it. I wouldn't need power steering then.
  4. Raffaelli
    Houston
    82 Longbed 2WD
    I don't thin ps came until 84. I useda later trucks ps box and pitman arm.
  5. KK5263
    KK5263 Newbie
    Ontario Canada
    81 V8 283 / 200R4
    Not sure if it came on a 2wd but it did come on my 83 4wd when I ordered it new. When the 93 comes I'll tear into it and see if it will work or if it would be easier to put a rack in or just leave it stock.
    Thanks for your input
