lifting my 1990
Discussion in 'Pre-1975 Build-Up/Project Threads' started by blackma12, Dec 4, 2012.
  1. blackma12
    blackma12 Newbie
    I'm planning on putting a 3in BL on to get it up off the ground. How big of tires will i be able to fit with that lift?
  2. 74Hiluxproject
    74Hiluxproject Enthusiast
    Olympia WA
    1974 Toyota Supra Truck
    idk but probably wrong forum
  3. 74Hiluxproject
    Olympia WA
  4. Da_Roach
    Da_Roach Toyotaholic
    NOVA
    (1) 92 RN80 (1) 2002 RZN150
    Im sure 30's would fit. I would look into a fabtech lift though. A few more dollers but better ride and look cleaner then body lift unless you get gap guards. Another way for lift and free is crank the t bars up. Again not great ride quailty but its free.
  5. ToxicToyz
    ToxicToyz Addict
    HI
    88 longbed
    Might wanna look into a suspension lift. If its a 2wd you could get an add-a-leaf and a lift shackle for the rear. The front you can either do torsions and a ball joint spacer or UCA and torsions. Most ball joint spacers will not work with the spacer
